02-03-2008, 08:26 AM | #1 |
Removing bolts from rear end
I started taking trailing arms off today to change springs, and shocks, the lower spring bolt broke off and the ubolts are stuck in the trailing arm, any hints from anyone to get them out without turning the truck over and hitting with the biggest sledge I can find, truck is on jack stands so not much room under to swing anything big.
02-03-2008, 10:49 AM | #2 |
sharp as a marble
Re: Removing bolts from rear end
I replaced my trailing arms recently, and had trouble getting the nuts on the ubolts loose. Had a torch avaiable, and got the nuts to unscrew. After that I drove a pry bar between the arm and the rear end. worked like hell, and did not give up and they came off. Might suggest trying to drive some king of wedge between arm and rear, lots of wd-40 and go at it.............
02-03-2008, 11:12 AM | #3 |
i agree with everything he said expect use a good lube liek pb blaster or something simliar ed-40 is used for water displacement
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-03-2008, 11:56 AM | #4 |
zip blade, cut the bolt in two above the trailing arm
02-03-2008, 09:23 PM | #5 |
Active Member
I used an angle grinder cut the bolt between the axle tube and the trailing arm, had the bolts (what was left of them) pressed out at the same time we pressed in the control arm bushings.
When I reassembled it I used anti seeze in the hole so that should not happen again
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
