Old 02-04-2008, 06:25 AM   #1
GMT900
GMT900's Avatar
Headlight switch knob
Simple for you not so for me. How do I remove this the knob off of the switch? Also how do I go about removing teh oil pressure line from the gauge? Any info would be appreciated before I tear something up.
The puppy barks but the trucks roll along.
GMT900 is offline   Reply With Quote
Old 02-04-2008, 06:29 AM   #2
71swb4x4
71swb4x4's Avatar
Re: Headlight switch knob
You don't remove the knob from the switch. The knob and rod it's attached too both come out. There is a button on top of the headlight switch. You press the button and then pull the knob and rod out as a unit. You will need to reach your arm up under the dash to get to that little button. It's best to unhook the battery first. When you pull the knob/rod out you are turning the lights on.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-04-2008, 06:30 AM   #3
corn
Reach up behind the headlite switch & you can feel a small knob on the top. Push down on it as you pull the knob out of the switch. You may have to turn the lights on, then do the push-pull trick. The oil gauge has a fitting that needs to be unhooked. Its right on the back of the gauge & I think its a 3/8 or 7/16 wrench. Sorry, its been a while sinse I did mine & cant remember the exact details...
corn is offline   Reply With Quote
Old 02-04-2008, 06:34 AM   #4
GMT900
GMT900's Avatar
You guys are aces. I guess I need to buy the manual
Old 02-04-2008, 06:54 AM   #5
cdowns
cdowns's Avatar
excellent idea
Old 02-04-2008, 09:21 AM   #6
71 super
71 super's Avatar
Knut is not 3/8 or 7/16 the knut on the line and the easiest to get out is 5/16 and requires a handstand to get it out.
71 super is offline   Reply With Quote
