Shaved Door Handles
Has anyone shaved their door handles on your truck? Kit popper kit did you use? Was it easy? Did you roll your own steel for the cutouts?
67' C-10 Project Truck Clinton Township MI My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=287690 |
BlahBlahBlah
Re: Shaved Door Handles
There was a member up here that had a set already nicely shaved he was trying to sell. If I can think of who it was Ill ask him how they were set up to open.
You know the pride thing. I would really like to do it my self just jooking for some info
BlahBlahBlah
Yeah I understand that. I was just going to ask him how he did it and how they popped open etc etc.
It would be way to expensive to ship doors from here to where you are at. |
wanna be 67
You can buy the cut outs right here through...ahhh.forgot who...but he sells on EBAY too. I used a auto loc system and it worked great.
How well does your system work? If you run across those cutouts let me know
wanna be 67
the EBAY # is 150211420331 and the seller is infanti72 hope that helps more. I love my auto loc system never had a problem with it. I think I have 45 lbs or maybe more not sure though. With heavy doors you need the bigger ones...IMO.
Here is a nice set up with an alarm for a few bucks more than other sellers are selling. This in an auto loc deal. EBAY # 110218386192 Installation was easy ands directions have nice pics. Last edited by 19stepSide72; 02-04-2008 at 11:31 AM. Reason: adding more information |
Official Site Guitar Shredder
i just cut out the door handle opening completely out...the made a filler panel to the exact size then slowly tacked it in solid light coat of mudd then glaze and its good to go.....very easy to do... as far as opening the door i drilled a 1/4 inch hole in the front of the door..and ran a small cable to the door handle rod....tacked it to the rod...as far as the cable goes i ran clear fish tank air hose inside the door and the cable runs threw it. and out the 1/4 hole i drilled....then i took the cable..and on one of the bolt holes through the fender i welded a small washer with a 1/8 inch hole in that, for the cable...did a simple loop and crimped the cable back to its self....works perfect...i did mine about 3 years ago . and have never had and problems....about every other oil change i simply oil the cable up a little ad its good to go......as far as door poppers ...i baught mine from...Street Scene...they are 20pnds poppers more than enough....hope this helps.....ya out............
ynot |
I just made my own filler panels out of steel. I have not finished my truck yet though so no poppers yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
Old Skool Club
![]() Join Date: Jun 2001
I thought about doing that with my truck, and let a friend talk me out of it. He already had a pair of doors ready for solenoids, too. Cost him some money and I guess I'm just gonna be content with the original plan.
Nice work thread, though.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Still livin the "dream" in '54
You can find "generic" poppers just about anywhere. I'm not sure anyone makes a "kit" that is made special just for your year truck. Look at the performance suppliers in your local area, or on line. What I have also used in the past were the gear driven door lock motors. They can be a bit tricky to install, but then again, so are solenoids. Installing poppers is a lot of trial and error. You have to try different mounting places and angles. You have to be mindful also of the clearance of your window as you roll it down.
A word of thought... Be sure to install a hidden switch in case you don't have your keyless entry remote with you, and be sure to install a pull cable hidden somewhere in the fender well area in case your battery ever dies. Trust me on both of these, I have had shaved handles on two of my trucks and these things DO happen. All of a sudden your "cool" truck looks really stupid when you and your girlfriend are getting wet because you can't open your truck and you are stuck in a parking lot at night after the show. A word on the welding. You can screw up your door in a major hurry if you rush it. Do not BEAD the weld. Use just as much heat as needed to get penetration, no more. Do some test welds first. Put a single stitch on the area then use water or compressed air cool the area BEFORE your next weld. THEN move to the opposite side for your next weld, and work back and forth untill the whole area is stitched. Check out my build page for some examples on how stitch welding should look when you are done. Takes a lot of time, but the amount of filler in the end will be alot less. Shaved handles are cool, but with the problems associated with them from past experiance, I chose not to shave the handles on my current build. The metal plates can just be made of some scrap you have laying around. If you feel you can do this yourself, then you can certainly cut your own plates. Hope this helps. D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 02-05-2008 at 01:52 AM. |
In the December 2007 edition of Custom Classic Trucks there is a really good tech article with a step by step on shaving door handles and installing an autoloc kit on a 67-72. I just searched their site but it doesn't appear to be online yet.
#13 |
wanna be 67
I TOTALLY agree with putting a hidden switch somewhere. Great tip.
#14 |
![]() Last edited by 463; 02-05-2008 at 12:22 PM. |
#15 |
www.infantimachine.com
We make the cut-out panels you need to shave your door handles.Like some folks say you can make them yourself if you have from some scrap metal lying around.If you want to save some time we would be happy to help you out. Gerry
#16 |
Thanks for the inforr - i will be ordering from you very soon
#17 | |
Commander Taco Bello
the kit they use is an autoloc kit with 50lb solenoids with "an 8 channel system". unfortunately, they didn't give a part number, but i would guess that the kit is easy enough to find. I'd also suggest contacting the guy on ebay that sells the filler plates for the handle and locks. i just ordered mine today and we'll see what kind of quality they are when they get here. |
#18 |
Someone needs to post location areas to mount the solenoids. Pics would be nice for our doors. Good thing I have a garage. I've been putting this off for a year next month.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#19 | |
Out of the carpool lane.
I've got another post on this subject and trying to figure it all out.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#20 |
i checked the CCT site and could not find this article online. I did find the part number after some google searching: SVPRO5
do a froogle.com search. i found one for about $250 with free shipping. if i'm not mistake (and i probably am) someone from CCT is a member to this forum, and may be able to provide a way to get back issues. i couldn't find a way to order them from their website. |
