Old 02-04-2008, 07:06 AM   #1
dazza
dazza's Avatar
Unlocking and locking - 4WD > 2WD
Over the last week or so, I started hearing a squeaking coming from my front end (72 K10 SWB), but only at lower speeds, about 20mph and below. It would come and go, but got worse. So yesterday I jacked it up, new bearings and u-joints ready to replace, and started reading a few things in two different manuals. Both manuals were persistent on the fact that once the truck is in 4wd, it must be shifted back into 2wd BEFORE you unlock the hubs. Now I started thinking about 3 weeks prior when I had it in 4wd and put it back ino 2wd, and yes, I unlocked the hubs first! So I took the truck back out, locked the hubs, put inot 4HI, it drove fine, no squeak. 4LO barely moved. Back to 4HI - ok. Shifted it to 2wd, unlocked the hubs and it drove great - NO Squeaking.
My question is: Did I do some serious damage?? I probably drove it this way for 6-800 miles. Is there a proper procedure for going in and out of 4wd? I know some 4x4's you need to reverse after going back to 2wd, is this required?
Any insight would be helpful.
Thanks,
Daz
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 02-04-2008, 11:27 PM   #2
RustyParts
RustyParts's Avatar
Re: Unlocking and locking - 4WD > 2WD
It makes it easier to unlock the front hubs when it's in 2WD because it relieves the bind on the front driveshaft.
Sometimes after running in 4WD the driveline will have a tendancy to bind up especially on dry surfaces and running the vehicle in reverse will unload it.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 02-05-2008, 04:57 AM   #3
dazza
dazza's Avatar
Thanks for the info.
Do you think driving it like that did any damage?
Old 02-05-2008, 07:57 AM   #4
1969K10
1969K10's Avatar
I can't see how you'd do any damage. I've driven with just about every combination of locked/engaged vs. unlocked/disengaged and combined of the X-fer & front axle, and haven't had any problems.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
