02-04-2008, 08:14 AM | #1 |
pics of a 1/3 inch drop
hi, i am thinking about getting a 1in / 2in. drop for my stepside, does anybody have any pics of this drop on a truck?
thanks in advance.
1967 chevy truck 350 V8 1973 VW Transporter/Hippy Bus 1964 VW Baja Bug "When the power of love overcomes the love of power the world will know peace"- Jimi Hendrix |
02-04-2008, 08:26 AM | #2 |
1972 Chevrolet SWB
Re: pics of a 1/3 inch drop
Early Classic Enterprises has a few great side shots of different drops on different trucks for referrence. Personally I think alot of people forget how much the trucks of these years have sagged along the years and if you attempted a 1-3 drop you may not noice any change. Ive seen it happen many times. 2-4 or 2.5-4/5 drops really make a different look thats very noticeable and are still fairly cheap,easy to install and ride great as long as proper shocks and bumpstops are used.
http://www.earlyclassic.com/tech.asp...nce%20Photos-2
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-04-2008, 08:34 AM | #3 |
thanks for the link, im not really wanting anything noticable, i just want something to even my truck out and maybe just a little bit of a drop. i live down a dirt road, so if i go much farther than a 1/3 i might not be able to go down the road lol
02-04-2008, 08:36 AM | #4 |
I agree with Slammed & Im just guessing, but Id say 1" drop front springs will raise your truck 1"...
02-04-2008, 08:56 AM | #5 | |
1972 Chevrolet SWB
Years ago I was told a-g body cars rear coils would drop out trucks nice in the rear,so I got a set for the rear and installed them on the back and when I was done my truck sat higher than it did at first. The age of these truck and the coils/leafs tenancies to sag over time actually lowers your truck already and when installing new drop coils and/or leafs you will be surprised the ride height might increase rather than drop. The link from ECE showing how they sit with certain drop packages clearly shows how high they were stock with new coils versus a 2-4/2-5 or a 4-6 or more.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. Last edited by slammed1; 02-04-2008 at 08:56 AM. |
02-04-2008, 08:58 AM | #6 |
1972 Chevrolet SWB
c-mack,I might suggest lowering the rear maybe 3-4 inches with a new coil first and then see how it sits in realation to the rear and if it sits level or with a little rake you could add a front spindle knowing at least the spindle will drop it the amount its made for without having to guess which frt coill may get the drop needed.
02-04-2008, 09:09 AM | #7 |
ok guys, thanks for all of your advice. i can tell that you know alot more about this stuff than i do. just wonderin, how much is air ride suspension setup?
1967 chevy truck 350 V8 1973 VW Transporter/Hippy Bus 1964 VW Baja Bug "When the power of love overcomes the love of power the world will know peace"- Jimi Hendrix Last edited by c-mack; 02-04-2008 at 09:11 AM. |
02-04-2008, 10:24 AM | #8 |
Fabricate till you "puke"
Here is a simple no guess deal.....clip 1 full ring off the bottom of the front coil(2 1/2" drop)., & go 2" block on the rear.....it should handle your dirt roads. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
