Old 02-04-2008, 08:26 AM   #1
Couch
Daily Driver
Couch's Avatar
spindles
i just recently acquired a 67 swb that has the crossmember swap out of a 73-87 in it, i was wondering,ive heard rumors that rotors from a caprice will fit on these spindles giving you a 5 lug car pattern. is this true?
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 02-04-2008, 02:44 PM   #2
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: spindles
Last time I was looking into that I found out Caprices had 5x5 pattern just like the trucks. Same as Crown Vics/Town Cars having 5x5.I believe you have to take a rotor to a machine shop to index a smaller pattern like 5x4.75. Im sure I will be corrected on this if I mixed up my info.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-05-2008, 08:15 AM   #3
65 on 24's
65 on 24's's Avatar
Re: spindles
caprice is that same i has the rear end out of one so i have rear disk
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 02-05-2008, 10:56 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: spindles
if it has a crossmember out of a 73-87 it should already be 5x5... and the caprice is 5x5...
so.... what are you trying to accomplish here?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-05-2008, 03:12 PM   #5
Couch
Daily Driver
Couch's Avatar
Re: spindles
i was wanting to go with a car five lug. more wheel availability. but it was just a thought.
Old 02-06-2008, 12:49 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: spindles
What kind of wheel is available for a 5x4.75 that's not available in a 5x5 pattern?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2008, 01:06 AM   #7
crazy longhorn
Fabricate till you "puke"
Re: spindles
Some of the early 70's vans had a 4 3/4" bolt circle.....I have not heard if the rotors will swap tho..... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-07-2008, 11:14 AM   #8
Couch
Daily Driver
Couch's Avatar
Re: spindles
not so much more available there is just more of a market for cheaper more readily available used wheels around.
Old 10-30-2008, 05:02 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Re: spindles
Raising the dead here- but for a good cause...
I found through some searching that when GM created the '81-up light duty(LD) trucks, they used big car 1" thick front rotors. The rotors are the same part number as the B-body(Caprice, Impala, Fleetwood, etc) w/ the 12" rotors- this was an upgrade for them- usually found on cop cars or wagons...
Knowing this- I also found that in the G-body(Monte Carlo, Regal, etc.), 2nd generation Camaro, and S-10 truck world, it is common practice to swap from their puny stock 10.5" brakes to 12" front rotors using B-body(big car) spindles. The way they get the 5-on-4.75 bolt pattern is by using '87-'92 Camaro 1LE brake rotors, which are the big car(or light truck) rotors with a small car bolt pattern.
What this means for us is if you have the LD brake package on your truck, either factory or swapped(like me), you can change to 5x4.75 bolt pattern up front for the cost of a new set of rotors, which I found at Advance Auto for $26 each.
Don't you just love GM's parts bin sharing tactics?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-30-2008, 05:41 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: spindles
But one thing to keep in mind
IIRC most drop spindles are for 1-1/4" rotors... if you plan to lower it
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-30-2008, 08:21 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
Re: spindles
W3rd. MOST. Belltech makes 3" drop spindles that are already installed. I've seen this topic come up quite a bit- just thought I would share a cheap solution...
-Chris
Old 10-30-2008, 10:24 PM   #12
bigblock73
yeller
bigblock73's Avatar
Re: spindles
Most mfr's offer drop spindles for 1" AND 1.25" rotors
bigblock73 is offline   Reply With Quote
Old 11-21-2008, 12:07 AM   #13
Rogue
Airport Bum
Re: spindles
A member of my Club, clipped his '59 Elco with a Caprice Interceptor 5on5.
He changed the rotor to the 1LE Z-28 Rotors to keep the 4.75.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
