02-04-2008, 10:08 AM | #1 |
Another Z'd frame question
Hi everyone,
I got my new truck (1965 LB) tore down and am in the planning stages of doing a 4" Z. How and where do you measure from to figure where your cuts should be? I did a search and could not find this information. Pictures would be great or if anyone is close that I could come and see it for myself. Thanks, Mark |
02-04-2008, 08:54 PM | #2 |
Re: Another Z'd frame question
not that have what yo are looking but where in Pa are ya
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
02-05-2008, 05:55 AM | #3 |
Anyone?
02-05-2008, 11:47 AM | #4 |
i has seen some awhile back but not couldnt find them this weekend.. i zed my frame 2 1/2 inches this weekend.. cut it right behind the radiator support mounts and then right behind the shock mounts..
02-05-2008, 02:36 PM | #5 |
thats were i cut mine as well, ill try to post pictures tommorow.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
02-06-2008, 09:02 AM | #6 |
[QUOTE=bedsled71;2562841]i has seen some awhile back but not couldnt find them this weekend.. i zed my frame 2 1/2 inches this weekend.. cut it right behind the radiator support mounts and then right behind the shock mounts.
When you cut behind the shock mounts how much room did you leave between the mounting hole and your cut? Thanks for your help! Mark |
02-06-2008, 10:50 AM | #7 |
it was about 2-3 inches behind the shock
02-06-2008, 10:51 AM | #8 |
02-06-2008, 11:02 AM | #9 |
Thanks for the link. Hopefully that will give me the courage to start cutting!
02-06-2008, 12:59 PM | #10 |
Here were i cut mine on my old frame...... Hope that helps, these are the only ones i have.
02-08-2008, 11:31 AM | #11 |
i cut mine right where the frame swoops down under the firewall. there is a small bend on both side that will act as a guide for u. look up "My SFBD 85" thread. it should have plenty of pics for ya!!! its the same frame so u should be ok...
Build thread:http://www.67-72chevytrucks.com/vboa...d.php?t=663953 Instagram: Whytry85 |
02-08-2008, 12:26 PM | #12 |
Thanks for the pictures that helps a lot! When you cut your frame did you measure from the A arm mounting point or from the front of the frame to make sure both cuts are in the same place? ( or doesn't it matter?)
02-22-2008, 03:43 AM | #13 |
(dont want to high jack this posting)
if you do a 2 1/2 z do you need to rise the trans hump or tunnel on the cab. |
02-22-2008, 04:28 AM | #14 |
Also do not weld straight up and down on your frame. make your welds at angles. An old timer told me that they are more prone to break when straight up and down.
VROD- I am su reyou have too. I did a 4 inch Z and raised my trans tunnel 4 inches also. Its not too bad of a task though.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
02-22-2008, 05:34 AM | #15 |
soon to be bagged64sub
I did mine the same as they are saying, a couple inches behind the shock mount and just behind the core support. The only real problem I ran into was with my radiator. I had a 4 core and the bottom hose doesn't work with the Z. Luckily I had a 2 core out of a 79 and it worked fine. I also cut the tranny tunnel as little as possible and just bought a high hump out of a 4 x 4 blazer and it just bolts right in and looks factory. Oh and I Z/d mine 3".
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
02-22-2008, 11:13 AM | #16 |
thanks for the info.
Im conver. my 4x4 Blazer to a 2wd so I guess I do not need to cut that much. |
02-26-2008, 09:55 AM | #17 |
i have a 60 and i want to z my frame 4", do i cut my frame in the same spots?
1960 CHEVY C10 1967 CHEVY C10 |
02-28-2008, 11:51 PM | #18 |
Does "Z"ing the frame cause any issue with removing the distributor like the dropmember does?
-wes |
02-29-2008, 03:15 AM | #19 |
I moved my motor to the front mounts and I dont have a problem at all. But then you have to have the driveshaft lengthened and move the tranny crossmember up.
02-29-2008, 08:54 AM | #20 | |
-wes |
