Old 02-05-2008, 05:24 AM   #1
Husker
Husker's Avatar
Had the Camera out, Fuel fill in bed
Here is how I did my Fuel fill in the bed. I will eventuly urethane coat the bed then it will look better. It is a later model blazer tank and fuel fill. I had to cut down the metal pipe on the fuel fill and rotated 180* then welded. Turned out ok. Tank hangs a bit low but I did not trim the bed crossmember, will probaly redo it later on.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-05-2008, 05:51 AM   #2
Re: Had the Camera out, Fuel fill in bed
Nice Job!
Old 02-05-2008, 05:53 AM   #3
Husker
Husker's Avatar
Thanks, Just another Idea for anyone planning the swap.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 02-05-2008, 06:15 AM   #4
s95930
A-Adam A-Adam
s95930's Avatar
Looks Great!!!
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 02-05-2008, 09:42 AM   #5
Brad
Out of the carpool lane.
Brad's Avatar
Mine is very similar but instead of the angle brackets, I just had a lip bent on the sheet metal to screw to my bed. What is that molding around the base where the hose go into the bed? That's a good idea.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-05-2008, 09:53 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That turned out great!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-05-2008, 01:07 PM   #7
Husker
Husker's Avatar
That is just a piece of 3/8" fuel hose split to go around the lip to prevent cutting the fuel hose. All the black paint is POR.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 02-05-2008, 01:09 PM   #8
shaneschevys
Its always something!
shaneschevys's Avatar
Nice!!
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 02-05-2008, 02:51 PM   #9
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
If I may pick your brain, it won't hurt too much...
What year is the fill pipe from?
Does it turn 90* under the bed or does the rubber hose make the bend?
Any part numbers?
I'm looking to do the same with my fill of a custom tank and you did a great job on yours.
Thanks,
lowrollin
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-05-2008, 10:43 PM   #10
Orange
Licensed to Thrill!
Orange's Avatar
Any part numbers?
Thanks,
lowrollin
Agreed.
This is exactly what mine is like almost.
I already have my bed but, and it's going to sit back a little farther into the inside of the bed, but I will have the same box that you have there.
I would like to know about your connections, etc. What you used to get down to the tank (flex hose), all that jazz.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 02-06-2008, 12:15 AM   #11
greasy68
greasy68's Avatar
I like this a lot. More ideas.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
