gear ratio ??
how do you find out what gear ratio your truck has ?I have a 72 c-10 with a 12 bolt rear end, and I heard that you can jack up one rear wheel and turn it and count the nuber of times the drive shaft turns. Is this right?How many times do you turn the tire?? thanks
Re: gear ratio ??
One full rotation of the tire. You can tape a piece of string to the driveshaft, which will make it easier to count the number of rotations.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
Re: gear ratio ??
The most accurate way is to count the teeth on the ring and pinion then divide the two numbers. The number will come out close enough to the numbers you hear for gear ratios to distinguish wich it is. Example a 4:10 gear comes out to 409 i beleive.
Everything is work in progress
![]() Join Date: Apr 2006
Re: gear ratio ??
Or look and see if your diff still has the factory tag on it. But it will only tell what came in it from the factory. However if you use the string method the tag could confirm your results.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
Re: gear ratio ??
the tooth count will be stamped on the edge of the ring gear i.e 11:41 then divide them = 3.73 rounded up...
yep, you need to take the cover off and then replace the oil but that's cheap maintenance...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#6 | |
Re: gear ratio ??
If you have a locker or limited slip, you will have to jack up both tires.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
