Instrument cluster assembly
well I am at the point that iI am installing my stock instrument cluster... for the light switch and the wiper switch for the 69 configuration, I have a star lock washer on each.... should these go on the inside of the steel dash or on the outside closest to the plastic cluster?????
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: Instrument cluster assembly
I believe they go on the outside at least thats where I put mine
69 Chevy 4x4 383 Power ![]() |
sounds like if it worked for you it should work for me..... thanks
