Old 02-05-2008, 07:25 AM   #1
icesickl
icesickl's Avatar
need a dash !
So I didnt realize that the metal dash was so hard to replace. Mine out of my 67 had some cosmetic issues, so I removed it. In the process of this it pretty much got destroyed to keep the windshield seal inset in tact. I went online to find my different options and I cant seem to find anything except dash pads. Am I looking at replacing the whole cab shell or cutting one out ? Does anyone make custom dashes for these, or is willing to ?
Drop it like its hot
icesickl is offline   Reply With Quote
Old 02-05-2008, 08:07 AM   #2
68chevy68
68chevy68's Avatar
Re: need a dash !
I am in the process of putting a 1959 edsel dash into my truck.
68chevy68 is offline   Reply With Quote
Old 02-05-2008, 08:12 AM   #3
EyeH8the24
EyeH8the24's Avatar
Re: need a dash !
have a free one i cut out of a 71 ...just pay shipping ...it is cut as close to the pinch weld as i could next to the windshield
EyeH8the24 is offline   Reply With Quote
Old 02-05-2008, 08:40 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: need a dash !
The easy way is to take the dash pad off and cut it across the slots where the dash pad bolts go through, then take out the three or four bolts that hold the bottom part to the cowl on the sides and it will come right out. That way you don't have to mess with the top of it. Of course you should have the gauge cluster and glove box liner out and the heater cables and wiring unhooked....
Sounds like you are past that now though. You will have to find a used dash and try to fit in in and get it welded. You may still have to pull the windshield out.....
LockDoc
Leon
Old 02-05-2008, 09:07 AM   #5
jwn1975
Re: need a dash !
When I replaced mine, I just cut it all the way across under the dash pad and un-bolted the ends. Welded all the little spots and replaced the dash pad, re-bolted and away i went. Cant tell at all!
jwn1975 is offline   Reply With Quote
Old 02-05-2008, 10:30 AM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: need a dash !
I pulled one from a crusher. Just couldnt bear to see a uncut dash get flattened. It works good for mockups
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-05-2008, 12:24 PM   #7
CG
BlahBlahBlah
Re: need a dash !
LockDoc
There are a couple of hidden spot welds underneath too. I tried to do this with an extra air dash I have. Cut across the slots, took out the bolts and there were a couple of spotwelds still holding it on.
Old 02-05-2008, 11:24 PM   #8
LockDoc
LockDoc's Avatar
Re: need a dash !
I haven't run into that. Maybe it's year specific..... Thanks for the heads up...
LockDoc
Leon
