Old 02-05-2008, 07:42 AM   #1
tjvending
tjvending's Avatar
Clutch Adjustment
I just install a new Clutch and Transmission. I'm trying to get the clutch adjusted, what is the corect way? I have about 1/4 pedal coming off of the floor and about 2 inches going in. What should it be?
TJ
tjvending is offline   Reply With Quote
Old 02-05-2008, 08:03 AM   #2
1969K10
1969K10's Avatar
Re: Clutch Adjustment
My rule of thumb is you need to be able to push the clutch pedal all the way in and have atleast 1/8" of movement before it starts to engage. You can have more, it depends on how you like your clutch to work.
The other end of adjustment (you've gone too far), has always been to get the truck on paved road, and put in high gear (4th?). You need to be able to stall the truck when you let the clutch out w/ the brakes on. If so, the clutch is fully engaged.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-05-2008, 08:07 AM   #3
crazy longhorn
Fabricate till you "puke"
A good rule of thumb......when its good & warm, if you can put the clutch down at a stop & go into reverse with no gearclash you are good to go. I like to see a diaphragm clutch start to take hold about 2 1/2" off the floor. Most books will have you set "freeplay" at the top to a certain spec(off the top of my head 1 1/4 to 1 1/2")....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-05-2008, 10:17 AM   #4
68gmsee
Active Member
68gmsee's Avatar
The way I adjust mine, is mainly by feel and what I like. About 1 1/2 to 2 inches of free play.
68gmsee is offline   Reply With Quote
Old 02-06-2008, 12:24 AM   #5
tjvending
tjvending's Avatar
How do I make these adjustment on the clucth Rod, which way to turn?
TJ
Old 02-06-2008, 12:54 AM   #6
crazy longhorn
shorten the rod on the bottom, to give more freeplay on top.....
