Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-05-2008, 08:13 AM   #1
1970chevy
Roll cage
Does any body know wear i can get a 8 or 10 point roll cage its going in 70 short box thanks
1970chevy is offline   Reply With Quote
Old 02-05-2008, 01:07 PM   #2
djracer
djracer's Avatar
Re: Roll cage
These guy can hook you up!
http://www.swracecars.com/
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-05-2008, 01:17 PM   #3
1970chevy
Re: Roll cage
thanks
Old 02-05-2008, 02:11 PM   #4
djracer
djracer's Avatar
Re: Roll cage
no problem they usually have a sale in the winter!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-05-2008, 02:25 PM   #5
bigjimzlll
bigjimzlll's Avatar
Re: Roll cage
yup S&W is the best. I bought a bunch of stuff from them...all good
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-05-2008, 03:08 PM   #6
57sailplane
57sailplane's Avatar
Re: Roll cage
wish i would of known. i bought one from chassis works it fit so bad that i tried bending it to fit and then it looked like hec. i ended up bending my own from scratch..
57sailplane is offline   Reply With Quote
Old 02-05-2008, 03:12 PM   #7
57sailplane
Re: Roll cage
oh ya i fogot to tell you that i called there teck guy twice and he said i was installing it wrong. ya ok tell my buddies that seen the pieces and then seen my work. terrible help. probably wont by from again. im sorry to rant but people should no...
Old 02-05-2008, 11:07 PM   #8
bigjimzlll
bigjimzlll's Avatar
Re: Roll cage
I bought the original roll bar from Chris Alston chassis works. The hoop "fit" but that's it.
Be warned that all cage kits made from mild steel will use seamed tubing. It will be .134" thick(which is good) and is perfectly legal. When I built my frame/cage I used .120" DOM tubing which is seamless. The DOM is also very heavy. If I was to do it again I would use Chrome Moly tubing and TIG weld. At the time I only had access to a MIG welder.
Anderson,CA
Old 02-28-2008, 08:02 AM   #9
1970chevy
Re: Roll cage
just got my 12 point s&w 1 5/8 dom tube roll cage whats the best way to try it into the frame
Old 02-28-2008, 09:17 PM   #10
bigjimzlll
bigjimzlll's Avatar
Re: Roll cage
I used 2x2 square tubing as out riggers. Plan the location for future stuff, liike exhaust. Also plan the rear down bars to hit the frame rails. One tricky part is the roll bar cross brace. If you put it str8 across the seat will be to far forward. Unless you are small statured you will have to bend the cross tube(where the shoulder harness ties too) to conform with the back of the cab. I'll see if I can find a pic. The reason there are 2 tubes on mne is because the bottom tube is too low...it wouldn't of passed tech, it was easier to leave it then remove it.
Anderson,CA
Old 02-29-2008, 06:24 AM   #11
Couch
Daily Driver
Couch's Avatar
Re: Roll cage
nice setup jim. im gonna copy it here in a little while. but i'd like to keep the factory dash, thinking of running the cross bar under it. but it may be more trouble than its worth
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 03-04-2008, 06:29 AM   #12
djracer
djracer's Avatar
Re: Roll cage
mine has the stock dash. you can see pics in my build thread.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
