02-05-2008, 09:54 AM | #1 |
RE: Inner Fender Seals
I bought new inner fender seals and I am getting ready to put them on...
Do I need the metal pieces from stock or do the LMC style just boly in? If so I have to find the metal parts which my body guy says he can't find both. Pictures please...
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
02-05-2008, 10:14 AM | #2 |
Re: Inner Fender Seals
You will need the metal pieces as the rubber parts from the vendors staple to the metal parts and the metal parts fasten to the cab pillars.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-05-2008, 10:28 AM | #3 |
Those are tough items to locate sometimes because it was part of the custom/comfort convience package, and there are not alot in junkyards. The staples that come with the replacements can be a bear to put into the metal pieces. You might check with uncle he has parted some higher end trucks and they may have had the brackets still on them.
