Old 10-21-2002, 09:29 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Powerwashed the engine this weekend
Rented a power washer this weekend. Worth the money, but there is still some hand work that needs to be done. Looks like I might need to get the flywheel resurfaced while it is off. It is a little discolored.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-21-2002, 09:50 AM   #2
Beast388
Suburbans RULE!
Beast388's Avatar
Big blocks are so cool!!
I would definately get that flywheel surfaced......it is cheap insurance for good clutch engagement. I bet you can't wait for that 454 to be in there instead of the 307!!
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 10-21-2002, 10:12 AM   #3
barn9
Half a bubble off!
barn9's Avatar
Hey Mark, that looks much better. I assume all that was coming from valve cover area, how does everything else look? What's the plan concerning the switch? Cya, LB.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 10-21-2002, 10:28 AM   #4
kpf
looks good,
some of the best money I've spent was for a pressure washer,
Now once i bring it out to clean something, everything I can think of gets cleaned.
71 c-10 6cyl
68 Camaro (wifes)
65 dodge town wagon (wanna buy it?)
97 crew cab f350 psd
kpf is offline   Reply With Quote
Old 10-21-2002, 10:55 AM   #5
Blazer1970
Blazer1970's Avatar
If you are putting in a new clutch, don't even think about doing it without having the flywheel resurfaced, no matter what it "looks" like.
Blazer1970 is offline   Reply With Quote
Old 10-21-2002, 11:03 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
How about the flip side. It's okay to use the old clutch, if it is in good shape with alot of life left, with a resurfaced flywheel, right?
Old 10-21-2002, 11:43 AM   #7
Mike C
Mike C's Avatar
I know it adds more to the budget, Mark, but the labor to replace the clutch pales in comparison to the price of a new clutch pressure plate. So even if your wallet (spouse!) cringes at the thought, surface the flywheel and get a rebuilt pressure plate and disc.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
