Old 02-05-2008, 02:17 PM   #1
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Marker light fill w/ rear tank?
Anyone done this? Found a pic of one done on a truck for sale. Said he used a Blazer tank... must have flipped it around for RH fill? Looks like it could be a finger slicer.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 02-05-2008, 03:05 PM   #2
panteratron
panteratron's Avatar
Re: Marker light fill w/ rear tank?
I HAVEN'T DONE THIS BUT I KNOW SOME PEOPLE ON HERE HAVE. IM GOING TO TRY THIS WHEN I GET AROUND TO IT.
http://67-72chevytrucks.com/vboard/s...d.php?t=222461
panteratron is offline   Reply With Quote
Old 02-05-2008, 07:27 PM   #3
He may have used a later model blazer/S10 blazer tank. They end up on the passenger side of the truck.
Old 02-05-2008, 10:30 PM   #4
Orange
Licensed to Thrill!
Orange's Avatar
http://www.classicheartbeat.com/mark...t_gas_door.htm
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
http://67-72chevytrucks.com/vboard/s...t=82178&page=2
I was going to go this route - but to do it on a fleetside bed - it's a pain.
You have to weld some ears in the hole, and it's a tighter fit than a stepper.
It's any standard under bed tank that works with our trucks with an S-10 filler neck and door.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 02-05-2008, 11:17 PM   #5
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I'm going this with my 69' Step Side. I'm gonna conceal the fuel fill behind the D/S rear marker light. I am using a Blazer Poly Tank and will use a Fuel Neck from a 97' S-10. I'm also using the hinge from that same S-10 which will be attached to the Marker Light. Since the fuel neck on the tank is 1-1/4" and the S-10 filler neck is 2", I had to be creative. Here's what I came up with. A copper reducer - 2" to 1-1/2" then 1-1/2 to 1-1/4". I used Silver Solder. (Copper Set-Up was about $20.00 at a local plumbing shop). Once the 2 necks were 1-1/4", I used a 1-1/4" Fuel Line between the two.
NOTE: The Blazer filler neck on the tank is 1-1/4" OD
Here's 2 pic's of my fuel neck with the reducers:
Here's a thread I saved and that I will us to finish my assembly:
Thanks Shawn (Board Member: Jorgensensc) for this great build thread.
Good Luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 02-06-2008, 04:36 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This is such a great mod. I've even seen the filler put behind the rear taillight as well as at the stop of the d/s rear stake pocket in conjuction with a marine filler.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-06-2008, 04:56 AM   #7
tdave00
Restoring a 68 SWB
tdave00's Avatar
I think this mod would concern me because the electrical wires are so close. Anyone else?
Otherwise I think it's a neat place to put it, especially if you widened the opening a little and made those edges safe so you don't slice your fingers getting the gas cap on and off.
tdave00 is offline   Reply With Quote
Old 02-06-2008, 04:56 AM   #8
70 longbed
I have almost completed mine. The tank is a custom tank, not a blazer tank and I started with searching for the info from old threads. There are a couple out there and they have lots of pics.
I used some different parts, and will have to list them, as they worke out quite well or me. I also used a cap frmone of the rod shops that you do not need to open,it has a spring loaded door the nozzle pushes through. Makes it real convenient.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 02-06-2008, 05:17 AM   #9
Frizzle Fry
Frizzle Fry's Avatar
The thing that stopped me from doing this was that many states (including the one I live in) have huge boots on the pump nozzles and that marker door opening is just too small.
Frizzle Fry is offline   Reply With Quote
Old 02-06-2008, 05:33 AM   #10
NONHOG
NONHOG's Avatar
Thats what I was thinking then I thought I never fill my rigs with the lights on ! That should end that ? I think ?
What about doing one of those filler doors then graft the light back onto it ?
Oh I shouldn't have said that now someone will do it before me
Probably already have.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 02-06-2008, 05:41 AM   #11
myoldchevytruck
Remember, this is a marker light/reflector lens - so there are no wires in this area. Even the Step Side Light Wire is nowhere in that area. Those wires, when run in the stock location come straight down and from the light assemblies and go under the bed sill under the tailgate.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-06-2008, 06:50 AM   #12
greasy68
greasy68's Avatar
It looks like the original picture would be a tight squeeze and kind of an odd angle to get the nozzle in. I can't think of any other cool place to put the filler though. Maybe behind the tail light with a swing out?
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 02-06-2008, 06:57 AM   #13
Frizzle Fry
That's been done and would be better IMO
Old 02-06-2008, 06:59 AM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The sidemarker mod was done by Tennman a member here(mostly inactive now)and he did a good write up on it.I think it's available on Wes's site.Someone also posted a rear light fill.I don't know if it made it to a FAQ or not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-06-2008, 09:44 AM   #15
kaycee
kaycee's Avatar
I have done this mod on my stepside marker light,no problem geting the gas nozzle in.We don't have them big boot things here like what was mentioned by frizzle.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is online now   Reply With Quote
Old 02-06-2008, 10:42 AM   #16
myoldchevytruck
Hey PanelDeland,
That's where I got the idea. I posted that build in my 1st post in this thread.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-06-2008, 11:03 AM   #17
72afr
Beep! Beep!
72afr's Avatar
i did this on my truck, however i havent set up the door system yet, so i just have to take off my marker light every time i fill up, but its not really that big of a hassle, should prolly get around to that sometime soon.....
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport
2003 Chevrolet 2500HD CC 6.0 4wd
2004 Jeep Rubicon some aftermarket stuff...
2019 Jeep Unlimited Rubicon (the wife's baby hauler)
72afr is offline   Reply With Quote
Old 02-06-2008, 12:09 PM   #18
Hart_Rod
Hart_Rod's Avatar
Here's a filler using the tail light that HUGGERCST did:
http://67-72chevytrucks.com/vboard/s...d.php?t=246851
Hart_Rod is offline   Reply With Quote
Old 02-06-2008, 01:16 PM   #19
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Thanks for the input everyone. My truck hasn't hit the road yet (except for a run up the road last fall) so I've been running around the yard on a gas can until I decide what I want to do. If I go rear tank, I might just put the filler in a recessed "bucket" inside the boxside. I'm still considering a tank under a crossover toolbox also. But the rear tank kit at $150 seems to be the no brainer. I'm going to be broke awhile, so I have plenty of time to make up my mind
Old 02-06-2008, 05:40 PM   #20
tdave00
Restoring a 68 SWB
tdave00's Avatar
Have you considered doing what SactoJim did and put it in the bed?
I always thought that looked pretty sweet.
Old 02-06-2008, 09:12 PM   #21
Orange
Licensed to Thrill!
Orange's Avatar
In case you guys missed it the first time around, I posted two threads (including the Tenneman thread) with this mod, and a website with this mod in it.
Also, the problem with the behind the taillight idea is that you have to do a lot of cutting, and if you are doing this on an already completed truck, it is almost impossible.
DLB
Old 02-06-2008, 09:39 PM   #22
myoldchevytruck
tdave
I definetly thought of the filler cap in the bed. I had 2 issues:
the 1st: the Blazer Poly Tank has a fill neck on the D/S of the tank at a 45 degree angle.
the 2nd: I am trying not get fuel on my newly stained and clear coated wood bed. The 2 don't mix.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-06-2008, 10:11 PM   #23
hilljob26
hilljob26's Avatar
thats my truck,i just posted some pics of it in another thread just a minute ago
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 12-18-2008, 03:09 PM   #24
lghtng2
That is awesome! I like how you added in filer weld in the groves to make it have a stock feel, this is exactly how I want to do mine although I think I'll want to do it towards the front of the bed since mines going to be for mudding... i really like the way it looks though
lghtng2 is offline   Reply With Quote
Old 12-18-2008, 03:45 PM   #25
Prostreet 72
Prostreet 72
Prostreet 72's Avatar
I like the idea, but would worry about melting the plastic lenses with the fuel. If you are running Leaded fuel, the plastic dosn't stand a chance. It is only made from PC ABS.
You might want to incorporate a splash guard made from a sheet of rubber to redirect any splash or over fill.
Prostreet 72
Prostreet 72 is offline   Reply With Quote
