Old 02-05-2008, 04:03 PM   #1
Scott Norris
deeper sump oil pan help
Can anyone recomend a oil pan for a 383 one piece rear main seal block in a lowered 72 4/6 drop.Would like to have a couple more quarts capacity than stock but dont want to drag the bottom off of it.Thanks
Scott Norris is offline   Reply With Quote
Old 02-05-2008, 09:07 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: deeper sump oil pan help
Its debatable if you even need the extra oil……FWIW you can get another quart or so with a larger filter, and have seen them mentioned on here. I would go that route on a lowered truck.
Hope this helps....
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-05-2008, 10:58 PM   #3
haysonj
haysonj's Avatar
Try these guys enpensive but have the best product out there. Will also build customhttp://www.dooleyenterprises.com[QUOTE=Scott Norris;2563214]Can anyone recomend a oil pan for a 383 one piece rear main seal block in a lowered 72 4/6 drop.Would like to have a couple more quarts capacity than stock but dont want to drag the bottom off of it.Thanks[/QUOTE
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-05-2008, 11:19 PM   #4
bigjimzlll
bigjimzlll's Avatar
You can use the readily available "kick out" style pan and pick up 2 quarts with out very much ground clearance decrease(maybe a 1/2".
One of the advantages is to have more oil and less windage. I will typically use 1 quart less than it's capacity(to lessen windage) and still have 1 quart more than stock.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
