#1 | |
Sierra Grande Club
How to install in intake?
I searched engine& drive train and this forum. The information I found has me concerned…..I have a felpro 1205 gasket, is it ok to use? I’m putting on a Edelbrock intake and only want to do this once! I plan on using ultra gray on the intake ends (in lieu of the rubber) and also on the bolts. Can I use Teflon paste on the bolts? I’ll probably find torque info in my shop manual or Google. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Prestige member Old Farts Club
Re: How to install in intake?
I used a stock gasket with alum intake with no problems and I just use ultra black for everything else, ultra gray is about same just rated for imports
Hey sombodys gotta do it! ![]() |
![]() Join Date: Jun 2006
I put a Edelbrock aluminum intake on my cast iron vortec heads using GM gaskets for a Vortec motor (I work at a dealer) You can use Teflon on bolts that need sealing. But I am a FIRM believer in proper torque on the bolts.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
#4 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 02-06-2008 at 04:31 AM. |
Dave's not here, man
When I did mine I didn't put any sealant on the bolts, but none of them had leaked before either. I used Ultra Black on the ends; I don't have any experience with the grey. Just make sure you lay a fat bead and torque the bolts in sequence. IIRC the torque is 35 ft. lbs. I'd check to be sure, though. Also, re-check the torque after a day or so. Mine always seemed to loosen up a bit after they got hot.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-06-2008 at 07:54 AM. |
Agreed with the re-tightening---I had a 375hp-396 years ago in a 69 Z-28 camaro (of course not stock motor) I had to re-tighten the intake about every 1000 miles sometimes 1/4 1/2 turn per bolt
Sierra Grande Club
does my felpro gasket sound like it will work? It's a 1205.
I wonder if a lock washer will help keep it tight. s/t
fugedaboutit
![]() Join Date: Mar 2005
iirc use teflon liquid tape on the inner 4 bolts on each bank. Also the ultra around the end water jackets.. check out my engine thread for some pics and some help from others when I did mine.. holding up great.. no problems
http://67-72chevytrucks.com/vboard/s...d.php?t=239740
Currently truckless ![]() |
blood type; Retumbo
1256 is stock ports, 1205 is small race, 1206 is large race ports.
check it against your heads and intake. |
#10 | |
Sierra Grande Club
![]() s/t
