Still Just Havin Some Fun!
![]() Join Date: Jun 2007
Picture please....
of an installed front sway bar? trying to see where to bolt it to the frame.
Thanks in advance!
a green one with some stuff done to it.... |
Re: Picture please....
Here is my Early Classic Enterprises sway bar installed.
Jeff's Current Vehicles: 1989 Turbo Trans Am Pacecar "Life is like racing, it goes by fast and has many turns" |
Hardway, is that front bolt inside the notch in the frame? I will have to drill a hole to mount the rear bolt.
![]() Join Date: Nov 2006
On mine, there was a small hole behind the slot. For the rear bolt you will have to remove your crossmember rivets. And a hint...remove one rivet, put in one bolt. It helps keep the crossmember straight.
Also, howdy neighbor! |
drman, what part of the great state are you in?
I'm around the Morrilton area.
Thanks Jimmy!
Tot Roddin'
Great info... I need to get mine mounted on my truck too.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
