Old 02-06-2008, 11:33 AM   #1
jwn1975
under bed fuel tank filler pics! Lets C em
Id like to see some of your ideas for filling the under bed mounted tanks. Im considering doing this and was wanting to see some cool pics. I was thinking going through the rear stake pocket.
jwn1975 is offline   Reply With Quote
Old 02-06-2008, 01:57 PM   #2
70 longbed
Re: under bed fuel tank filler pics! Lets C em
Not finished, but a little different than most.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 02-06-2008, 03:25 PM   #3
wibilly
wibilly's Avatar
/wibilly/IMG_5229.jpg[/IMG] here's mine
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 02-06-2008, 03:31 PM   #4
wibilly
wibilly's Avatar
Old 02-06-2008, 09:51 PM   #5
hilljob26
hilljob26's Avatar
here is mine
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-06-2008, 09:53 PM   #6
hilljob26
hilljob26's Avatar
one thing that you have to be aware of is the angle of the neck,i had to cut out the whole center of my filler neck so that the gas hose didnt bind when filling,otherwise it takes a freakin hour to fill up,since i cut out the center,it works great
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-06-2008, 10:10 PM   #7
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Hey Guys,
Were having a similar discussion in another thread right now, talking about pros and cons of the filler neck behind the marker light.
Wibilly, your mod came out nice and clean. Great lob.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 02-10-2008, 12:26 PM   #8
BP68
BP68's Avatar
I am doing mine behind the left taillamp like Yank.
Post #23
http://67-72chevytrucks.com/vboard/s...d.php?t=178962
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 02-10-2008, 01:23 PM   #9
cflvulcan
cflvulcan's Avatar
just a quick question for those who put the filler in the side marker. can you take the gas cap out of the hole? it looks really tight...
cflvulcan is offline   Reply With Quote
Old 02-11-2008, 06:21 AM   #10
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
here's mine in a rough stage, but everything works, and fills pretty fast(well it does once I put a vent tube in!)
I did manage to re-use the stock filler from the cab, and there's just enough space to get your fingers in to get the cap off.
I know that Yank and HuggerCST also have done this to fill their tanks, HuggerCST's came out really well. Between the way he boxed up the filler area,The hinge/Spring mount and the LED taillight makes for a really clean install.
I think HuggerCST and Yank taillight hinges part way up the light, so the bottom of the light folds into the bed. Mine is hinged right at the bottom, and completely folds outward.
I will probably rework mine with a LED once I get the cab fixed up to get the bulb socket and wires outta the way.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 02-11-2008, 06:31 AM   #11
Mudder
Mudder's Avatar
They make a cap you do not have to remove to fill.
Mudder is offline   Reply With Quote
Old 02-11-2008, 07:30 AM   #12
Mine is not all they way done, but I have a factory 72 Blazer tank, and used a filler and body panel with the filler door from a 88-98 C1500.
You can see more details in the build the of my signature.
Palf70Step is online now   Reply With Quote
