Wheelin' and Dealin'
cheapest rear mounted gas tank
my dad says he saw one on here the otehr day for 25 bucks, but now we cant find it, we took the old tank out, its like mint condition, how much could i get for it, and what is all teh tanks i could fit back there between the frame
thanks, L Zember
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
Re: cheapest rear mounted gas tank
not sure on the years but some blazer tanks fit well
![]() Join Date: Sep 2006
There is a thread out there. You can veiw it here. http://67-72chevytrucks.com/vboard/s...d.php?t=276902 If you want to see a blazer tank installed you can see mine here. It is not finished yet though. http://s49.photobucket.com/albums/f2...t=000_0345.jpg
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 02-07-2008 at 12:44 AM. |
I just purchased rear mount tank from LMC for $200 bones, really couldn't afford it it but really wanted tank out of cab. so I forked it over.
![]() Join Date: Aug 2005
Blazer tnak on the cheap link in my sig. Not sure if they sold out yet...
chevy only
Cpp Is The Cheapest On New One, If You Get A Cheap Used Tank Make Sure It Clean Inside And Usable
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 02-07-2008 at 05:02 AM. |
$25 junkyard find. This probably won't work on 63-66, but it work great on our 62 (which has a wider frame).
I found a '85 or Suburban in the junk yard. Had the 34 gallon tank, straps, sending unit. I bought the whole thing (including 1/4 tank of stale gas) for $25. We took out the cross member just behind the axle and built a new one for the rear of the frame. We bolted hook the tank straps the to crossmember that is over the axle and to the new rear crossmember. Hooked the fuel line to the vent on the sender. Used another hose to hook the output and input lines from the elc pump to each other, effectively closing thos ports off. Works like a champ. Also put in a 0 - 90 gauge and hooked to the sending unit. Tony |
OK another stupid question. Why are guys moving your tanks?? Is it for safety, room or some other reason??
http://public.fotki.com/fuelpump |
I just don't want the gas smell in the cab,and it gives me more options for my stereo. also provides a little more traction in the rear end.
#11 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 02-15-2008 at 11:02 AM. |
o man thanks alot soon as the local junk yard opens ill be there with bells on
