Old 02-07-2008, 04:48 AM   #1
hotrodhomi
hotrodhomi's Avatar
polyurethane control arm bushings
Has anyone been unhappy with their polyurethane control arm bushings? I just bought a set of control arms and I need to replace the bushings. just trying to get figure out if I want to stick with the stock style or not. It will be bagged if that make a difference or not.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-07-2008, 04:58 AM   #2
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Re: polyurethane control arm bushings
I have used both and never noticed a major difference. I figure if the originals held up for 35 years,why not stick with them.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 02-07-2008, 07:32 AM   #3
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
I have used stock, polyurethane, & polygraphite. The polyurethane seemed to make alot of noise. It handled well, better than stock. There where other suspension upgrades along with the bushings which where a factor. The polygraphite are alot like the polyurethane but not so noisey. Thats just my opinion. Right now I'm using the polygraphite in my burb and they work well.
GMBowtie79 is offline   Reply With Quote
Old 02-07-2008, 07:55 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Squeak, squeak, squeak... Use rubber or polygraphite or be prepared to lose your mind.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-07-2008, 09:52 AM   #5
abadsvt
abadsvt's Avatar
I hope they aren't as loud as you all are leading on too. I just replaced all of my control arm bushings with all new poly (not sure if they are polygraphite) because i needed new ones and the advantages in handling. That is going to suck if that is true
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 02-07-2008, 09:59 AM   #6
abadsvt
abadsvt's Avatar
I just double checked and mine are graphite impregnated so does that mean that they are polygraphite bushings and I should be fine with the whole squeak thing? Sorry didn't mean to hijack you thread
Josh
(Project truck)
Old 02-07-2008, 10:12 AM   #7
hotrodhomi
hotrodhomi's Avatar
Josh
Where did you get them?
'66 impala ht
Old 02-07-2008, 10:30 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, graphite impregnated is GTG. Check with Energy Suspension or ProThane. Those are the two top names in the business.
-Chris
Old 02-07-2008, 12:36 PM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
If you do use polyurethane make damn sure that you grease the crap out of them inside and out. Otherwise, they will squeak like Gringo said. I have polyurethane in the rear of my 66 Chevelle and have no problems though. But, I have heard of some poly's squeaking.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-07-2008, 12:45 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Yep. Use their silicone grease too. Normal petrol grease will only last a couple of days and then start back grating on your last nerve again. The stuff specifically made for poly bushings lasts forever and is hard as hell to wash off, even with soap...
-Chris
Old 02-07-2008, 02:46 PM   #11
hotrodhomi
hotrodhomi's Avatar
Do I need a press to get these in? What type of places do this and is it expensive?
'66 impala ht
Old 02-07-2008, 03:19 PM   #12
abadsvt
abadsvt's Avatar
I have different ones than what you would use because i am using a c5 corvette suspension so i used poly bushings for corvette control arms.
So do i need to make sure that there is tons of grease in the bushings even though mine are graphite injected?
Josh
(Project truck)
Old 02-08-2008, 10:28 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, to get the old ones out and to install the new ones. You local tire and alignment place should be able to do it, or refer you to someone who can.
Can't hurt. It would suck to not do it, then have a squeaky azz suspension later. I use this stuff on every poly bushing I install:
-Chris
