Old 02-07-2008, 08:11 AM   #1
daveo68
daveo68's Avatar
Brake Switch ?
I just put front disc brakes on my truck and was wondering how to hook up the switch that goes to the proportional valve. Also where is the switch that makes brake warning light come on in the dash panel for standard drum brakes?
Thanks,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 02-07-2008, 08:47 AM   #2
bob1967
bob1967's Avatar
Re: Brake Switch ?
I think, could be wrong, the wire on the proportional valve goes to a low brake fluid light. The brake light switch on my 67 is right behind the peddle, pain in the a$$ to get to
bob1967 is offline   Reply With Quote
Old 02-07-2008, 09:05 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Brake Switch ?
Originally Posted by daveo68 View Post
I just put front disc brakes on my truck and was wondering how to hook up the switch that goes to the proportional valve. Also where is the switch that makes brake lights come on in the dash panel for standard drum brakes?
Thanks,
Dave
The switch you refer to is built into the p-valve and is operated by hydraulic pressure and springs inside the valve. The tan wire in the picture below hooks to the p-valve switch and runs to the brake warning light in the dash.
If you did not use a newer disc brake master cylinder and p-valve you may not get enough fluid volume to the front brakes and the rears may lock up before the fronts.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-07-2008, 09:12 AM   #4
daveo68
daveo68's Avatar
Re: Brake Switch ?
I have the newer m/c and prop valve.Doe's that tan wire run to the top of the new prop valve, or is there another part I need?
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 02-07-2008, 07:14 PM   #5
daveo68
daveo68's Avatar
Re: Brake Switch ?
Ttt
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 02-07-2008, 11:31 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Brake Switch ?
The tan wire that was hooked to your old prop valve should be hooked to the new one.and the rear brake light switch is on the pedal under the dash
sneakysnake is offline   Reply With Quote
Old 02-08-2008, 02:47 AM   #7
daveo68
daveo68's Avatar
Re: Brake Switch ?
I found the wire, it was under the wiring gutter on firewall.Where can I get the connector and pigtail that plugs into the newer type prop valve for brake warning light?
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 02-09-2008, 12:28 AM   #8
daveo68
daveo68's Avatar
Re: Brake Switch ?
Any board vendors have or know if you can get the connector and pigtail that plugs into the newer type prop valve for brake warning light?
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 02-09-2008, 01:36 AM   #9
sneakysnake
Re: Brake Switch ?
Junkyard would have one,Or I think this will work.
http://www.performanceonline.com/sto...cat=665&page=2
Old 02-09-2008, 06:28 AM   #10
daveo68
daveo68's Avatar
Re: Brake Switch ?
Just got back from the junkyard and got two for $5.00. The one from Performance Online is the same except the two I got are 90 degree at the top.
Thanks for all the help everyone,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
