Old 02-07-2008, 08:41 AM   #1
Gray Ghost
Gray Ghost's Avatar
Which wire for lights on a guage?
I have forgotten which wire I need to tap into to get lights to my temporary water temp guage. CRS is a sad memory loss disease...hope most of you never get it....
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-07-2008, 08:55 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Which wire for lights on a guage?
I taped into the A/C panel lights. If you have the heater only tap into the singal light bulb wire for hot then ground the gauge. It will dim with the headlight switch as the other's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-07-2008, 09:24 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no need to 'tap' into anything.
On the fuse box there is a spade specificly for this.
Old 02-07-2008, 12:19 PM   #4
Gray Ghost
Gray Ghost's Avatar
On this diagram which one is it?
Kelly
Old 02-07-2008, 09:01 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cluster feed. TOP CENTER
I just didn't want to run the wire over to the fuse, the light bulb is right above my gauge so it was simple to do.
Old 02-07-2008, 09:52 PM   #6
Gray Ghost
Gray Ghost's Avatar
Cool....thanks guys!
Kelly
Old 02-11-2008, 02:37 AM   #7
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
You know you've got CRS pretty bad when you can't remember what it stands for ................
68shortstep is offline   Reply With Quote
Old 02-11-2008, 03:06 AM   #8
Longhorn Man
CRS
can't remember stuff... thats what i always told my son, but he knows better now. I have a huge CRS sticker in the tool box in the back of my truck.
Old 02-11-2008, 11:47 AM   #9
Gray Ghost
Gray Ghost's Avatar
Close....can't remember sh_t....
Kelly
