Old 02-07-2008, 08:43 PM   #1
isabela62
assist in lift 70 chevy
i need some assistane with my 70 chevy 1/2 ton. want to put a lift kit 4 to 6 inches but all kits i c have leaf springs, but my truck dosent . so do i need to modify my chassis, or what to lift my baby. do the 4x4 come with leafs from factory.
isabela62 is offline   Reply With Quote
Old 02-07-2008, 10:04 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: assit in lift 70 chevy
so the truck you want to lift is 2wd?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-08-2008, 08:30 PM   #3
isabela62
yup its a 2 wheel drive. thanks for the reply any help will be appreciated.
Old 02-09-2008, 11:48 PM   #4
hilljob26
hilljob26's Avatar
you have a couple of options,one is to turn it into leaf in the rear,or buy longer springs for the rear,the rear is the easy part,the front is the kicker,you will almost need some kind of spindle that is longer then normal,i think you can get about 2-3" out of the front with longer springs,but i dont think you can get anymore
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-11-2008, 03:35 PM   #5
mudmizer
mudmizer's Avatar
I agree with hilljob, the rear would not be too difficult. I would use longer springs on the rear or some quality spring spacers or cups on the top end. I have always wondered if a block could be added to the rear just as if it were a leaf sprung truck. I'm sure someone else here could tell us if blocks would work. The front woud be the problem. If you spring up the control arms too much it is going to kill the angle of your tires and wear them out pretty quick, look funny and handle a little wierd. If you are really serious about doing it I would get a straight axle, like out of an old ford or somthing, not a driven axle, and swap it out. Would be a lot of work. Leafs and all. If you don't mind body lifts then a 2" body lift (don't go any bigger on a body lift then 2", they start effecting too much stuff and look bad)with a little extra spring in the front and rear should give you about 4" and I think the front control arm should be OK with just 2" extra spring. That might be the easiest way to go.
Good luck.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 02-17-2008, 04:08 AM   #6
ERASER5
ERASER5's Avatar
Re: assist in lift 70 chevy
Yes, all the factory 4X4's came with leaf springs. Mounting the trailing arms on top of the axel will give you about 3" of lift. Add a 2" block and you are at 5". Someone posted pictures of this setup, probably on the 4X4 board.
I too want lift my truck, but only about 3". I have not found a good solution yet, but I am sure there is one. More research ahead.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
