Old 02-07-2008, 09:15 PM   #1
70GMCer
70GMCer's Avatar
Is this the right bracket?
I can't get anymore adjustment out of the alt bracket, and I can't use a smaller belt due to the valve covers. Is the adjust arm in the right position?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-07-2008, 10:07 PM   #2
Luvlegs
Luvlegs's Avatar
Re: Is this the right bracket?
Isn't there another bracket that looks just like that only it's a bit higher up to the arc and longer over the alternator? Other than that, it looks right to me (but, who am I...)
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-08-2008, 02:01 AM   #3
hyarbour
I had that problem with my old engine. On the new one I moved the alternator to the othe head.
hyarbour is offline   Reply With Quote
Old 02-08-2008, 02:30 AM   #4
70GMCer
70GMCer's Avatar
Moving to the other head is not an option. I know that the alt was original on the right side. All the pulleys align up perfect. I'm wondering if I don't have the adjustment arm in the right place on the head or is that the wrong arm I have?
1997 GMC Sierra Ext
1965 Mustang
Old 02-08-2008, 02:30 AM   #5
TotalChevy1
TotalChevy1's Avatar
That bracket looks a little small Here's a pic on mine not sure it will help
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 02-08-2008, 03:11 AM   #6
bdozeraz
bdozeraz's Avatar
I ran into the same problem on mine when I went to aftermarket valve covers. I think the aftermarket ones are a little wider and taller than the stockers. I got the next shorter belt and had to loosen the alternator mounts so I could tip it in to get the belt started and then tightened the wee out of the belt to get the alternator to just clear the valve covers. The belt eventually stretched a bit and it was ok. It is not real good on the bearings in the alternator though.
bdozeraz is offline   Reply With Quote
Old 02-08-2008, 04:17 AM   #7
john
member #16
john's Avatar
I have heard the 72 brackets are longer.
john is offline   Reply With Quote
Old 02-08-2008, 05:26 AM   #8
70GMCer
70GMCer's Avatar
those 2 pics do look like the sweep is longer. The valve covers I have are not that tall. I bought this arm at GM last year. I found this on Ebay, and it looks like the adjustment slot is longer. It's supposed to be for a late 60's Corvette. Could one of you guys measure the slot opening length on the arm? I want to see for sure if mine is shorter before getting another one. Thanks.
1997 GMC Sierra Ext
1965 Mustang
Old 02-08-2008, 07:00 AM   #9
Blazer1970
Blazer1970's Avatar
Yes, this is true.
Blazer1970 is offline   Reply With Quote
Old 02-08-2008, 01:24 PM   #10
TotalChevy1
The distance between the mounting bolt the the end of the slot is around 12 inches, which may only be about 1/2" longer, which would make a difference. My Alt. is pretty close to the valve cover
Old 02-08-2008, 02:17 PM   #11
LILRED66
LILRED66's Avatar
I had the same issue and moved the end of the bracket to the threaded hole in the intake manifold and not the head. This required a small spacer for correct belt alignment. Worked great and allow lots of adjustment.
LILRED66 is offline   Reply With Quote
Old 02-09-2008, 01:04 AM   #12
BigSky71
LAIDOUT
BigSky71's Avatar
My experience exactly, I bought the next two shorter belts, figured out the one that worked and took the other back.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
