Air Cleaner flow
I have read of some testing of different air filter flow capabilities....... and the plain old stock housing with it's air horn is realy kinda hard to beat...............anyone else here have knowledge of this????
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: Air Cleaner flow
Not sure about the stock air cleaner, but I did read of an independant test and surprising the AC Delco paper air filter from GM did as well as any of them and definately better than a K&N which is very hyped and overated. Not my opinion but the research group that did the test. And seeing as how they spent several thousands of $'s to do the test I'd be very inclined to go along with that! GM spends millions of $'s in research and while theres trade offs to performance for the average masses it only makes sence to do a bit of research to determine your parameters. I have a friend a Father and Son o
Well dont know what happened here but......... anyway. I know of a dyno shop that can show comparisons for the open element and hi-performance housings and it very interesting the hi-perf option has better #'s and smoother operation and the carb dont ice up as with the open element. Now in higher temp lower humidity climates open elements seem to work ok. The dyno shop was in Mount Vernon, Wash.
when i was in engineering school, i worked in the engines lab and we did a study/experiment of this very same thing. the stock air horn type cleaner housing dyno'd with more torque. the only reason it is better is because the snout will pick up cooler air from the front of the engine bay. the flow restriction is negligible when compared to an open aftermarket style.
![]() Join Date: Jan 2007
That's actually very interesting. Those K&N filters are expensive.
Yea! serious gearheads will not argue with Dynos ,flow benches etc. just look at nascar engine building and the depth that they get into things many capable mechanics dont even know about or understand! Even the Popular Hot Rodding mag engine builders shoot out.... Potter Aumotive spent BIG $'s and around 1200 hours on the Cad 500 they entered. Luv that TORQUE !
i have never seen a K&N do anything for a carb'd chevy engine. i have seen a honda accord pick up alittle more power with one. i guess they work best on the closed intake systems of a fuel injection system.
![]() Join Date: Dec 2006
I brought this subject up once over in the Engine and Powertrain forum and it seems that the open air-filter set-up is partly for the sound it allows. Apparently they look cool too,but if you actually want to go faster,cool air is the ticket IMO.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
This chart was posted in Doug Roe's Rochester book. It referenced a Holly test from '71
Cleaner type -------------------------------------------- CFM(WOT) None --------------------------------------------------- 713 Chev 396 closed element with single snorkle --------------- 480 Chev 396 closed element single snorkle cut off at housing -- 515 Same as above but with two elements -------------------- 690 Chev high perf open element ----------------------------- 675 Same as above but two elements ------------------------ 713 14" open element accessory type air cleaner ------------- 675 Chev truck type tall element used with accessory type base and lid ------------------------------------------ 713 Foam type cleaner(doomed flat funnel type) -------------- 675 This test was done with paper type elements in all test except the last one. Personally I don't have an original air cleaner on anything I own. When I did run originals I always flipped the lid and put the tall filter in.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
Now I hear that the oil used on the K&Ns can foul up a fuel injection system
#11 | |
I had one in my Regal for a while and the dealership said that the oil can mess up the mass air flow sensor. Not sure if this is true or not but they threw away the K&N I had in there.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
its all about the +6 inches
yes, if over oiled, it can damage the MAF sensor
#13 |
TowMater
I have read this as well. The post I read also said that to clean the MAF to only use brake parts cleaner because it leave no residue?????
Just my 2 cents
Don't take life too seriously, you'll never get out alive. ![]() |
#14 |
Sandwich: Club
I had a K&N foul my MAF too. Million miles my a$$. I gave it a ride about 15 miles to the dump.
They make MAF sensor cleaner; I found some at Advance Auto Parts. |
#15 |
Parts and more parts
I have been running K&N filters on my vehicles for years. The 1988 Nissan (fuel injected 2.8 engine), 2 Luminas (1991 & 1998--both fuel injected), and the 95 Impalla SS (fuel injected with a K&N FIPK) have had no problem with the sensors. The vehicles all run great and I have had no issue with them for many years and many miles. Everyone to their own taste. The carbs and the TBI units are clean. On my 383 stroker motor, I run a K&N Extreme filter top and that opened up the air flow from the cowl hood scoop to the carb.
By the way, if the dealership threw the K&N away, they owe you for it. It was not theirs to do that with. Last edited by piecesparts; 02-16-2008 at 06:35 AM. |
#16 |
![]() Join Date: Dec 2004
I did a dyno test a few years back with a K&N vs a dirty Fram filter and a new Fram filter, the engine was a healthy 350 and I used the stock filter housing from my 85 Blazer. The K&N beat the dirty Fram by 5HP and the clean Fram by only 2. Some tests I have seen claim the K&N dosent filter as well but its done fine in my 97 Pontiac with 188000 miles
#17 |
am using the stock element in my own custom creation ...................
![]() Hey I might patent the thing!!!!! ![]() Okay .....pictures soon!! In the meantime this pic should hold ya all over.... Aerostotle settin there on my right shoulder is one Bad Boy!!!! ![]() The other bird is my day job!!!!
#18 | |
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
#19 |
I have seen a lot of unregular guys run just "cool Lookin" stacks. I guess the question is where and when and how much do you drive it. $20 for every 20k miles? I replace my house filter all the time and don't feel the least mad about it. I like your bird by the way. David
#20 |
well here it is in it's prototype stage.........I am not sure if i am staying with the orange or not. The POR 15 Chevy orange doesn't paint well on smooth surfaces.............................kinda like a krinkle finish.. i also thought about flat black and the orange......not sure yet.
so what you see is the snout removed from a stock housing then a template cut from that opening and then cutting out an total of 5 "windows" around the lower housing.... Roswell anyone??
#21 |
okay here are the pics...................sorry i missed them above
#22 |
![]() Join Date: Oct 2001
I saw a test once where a new paper filter was slightly better than a K&N but as they got dirty the paper went away faster.
As for open element filters Hot Rod did a test some time back showing a hp and torque increase with a raised base over a low base like you would need for hood clearance. Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
#23 |
black is better!
