02-08-2008, 01:10 AM | #1 |
HELP! My Throttle Cable Pops Out!
My throttle cable doesn't want to stay in the bracket attached to the 4bl carb. It kind of slides out. Am I missing a keeper or something?
Dan |
02-08-2008, 01:47 AM | #2 |
Re: HELP! My Throttle Cable Pops Out!
haha. no really,. what dort of bracket is it? can you snap a pic. not sure what you missing without knowing what you have. |
02-08-2008, 02:39 AM | #3 |
If you're running an Edelbrock style carb, you need a "throttle rod stud". The one I bought is an Edelbrock piece. I bought it off of a recommendation here. I put it on when I installed the carb and except for when I attached the aftermarket cruise control, I haven't touched it.
I hope this helps.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-08-2008, 05:39 AM | #4 | |
One thing to consider. If you look in the picture I posted, the gold colored bracket I used for my th350 kick-down cable was also an Edelbrock piece. I had a straight stick previously and with the throttle rod, I had no kickdown/throttle cable piece. If your bracket is bad you maybe could try that piece. However I'm guessing the plastic housing that clicks into the bracket is buggered up. In which case you'll need a new cable.
02-08-2008, 11:34 AM | #5 |
Dan, I was having the same problem with my 72 big block truck too!! I just put a wire tie on it for now, not sure how to fix it correctly yet.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
