02-08-2008, 07:37 AM | #1 |
Junior Member
Carrier bearing question
I asked about U joints yesterday and was advised Spicer was the best so I picked up 3 from the driveshaft shop. He looked at my carrier bearing since he said there was a choice of 2 different ones. Upon inspection he informed that I have neither of those but I have one with a split metal housing that the bolt centers are 5 7/8 as opposed to the other kind that is 6 1/2 and the bearing sits at different height. He said the kind I have is obsolete. Any one know what in the hell I am talking about and if so where I can get one. Thanks
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-08-2008, 08:17 AM | #2 |
Re: Carrier bearing question
You probably have the same kind I had in my 69 GMC. Everywhere I tried to get one said it was obsolete and none were available in universe. I ended up buying the newer style bearing and making some spacers so it would mount at the correct height. If you could post a picture of it , I could tell you for sure.
"Negative people always seem to have a problem for every solution" |
02-08-2008, 11:08 AM | #3 |
I think I've got the same kind. I need to replace it sometime fairly soon. Does it look like this?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-08-2008, 11:15 AM | #4 |
Yep, that's just like the one I had. All you need to do is to get the newer "horseshoe style" bearing and make some spacers where it will be at the correct height.
02-08-2008, 11:23 AM | #5 |
the 69 wrecker i just bought has one like that , have owned alot of these trucks and its thefirst i have ever seen,was probally to strong so they had to replace it with the wimpy one
02-09-2008, 11:12 AM | #6 |
Junior Member
That is it. Anyone know where to get one?
02-09-2008, 11:52 AM | #7 |
Broken Down
You will have to get the new style unless you find a cross referance part number. Can you see a part number on that piece?
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
02-12-2008, 03:40 AM | #8 |
Junior Member
Looks like the same one. Anyone know where to get one?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 09-03-2009 at 03:23 PM. |
02-12-2008, 11:18 AM | #9 |
Check out Neapco P/N 212050x. Otherwise you just need the inside bearing diameter, find one with the bolt width you need, and shim to get same height as your original. Good luck!
02-13-2008, 01:59 AM | #10 |
Junior Member
Anyone know the inside bearing diameter for the carrier bearing shown in the above pictures?
02-13-2008, 05:10 AM | #11 |
Junior Member
I am so confused. LMC lists 3 differnt bearing diameters. Anyone know which one I have by the picture.
