Old 02-08-2008, 07:53 AM   #1
ksbeatty
ksbeatty's Avatar
Front Fender Seal Set
Has anyone installed this kit from LMC? If so or not do you need the stock metal or is it just a bolt in now?
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 02-08-2008, 08:10 AM   #2
71 super
71 super's Avatar
Re: Front Fender Seal Set
You need the stock metal brackets
71 super is offline   Reply With Quote
Old 02-08-2008, 11:15 PM   #3
ksbeatty
ksbeatty's Avatar
Is it just a staple on then like factory?
Old 02-08-2008, 11:41 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Excuse my ignorance, but what is this metal brackets that I hear about for the inner seals? Is this just for a certain truck? I don't recall mine having them.
Thanks...
68gmsee is offline   Reply With Quote
Old 02-09-2008, 02:42 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't think the pickup trucks had them, or so I've been told by a vendor in my area. He says they're for Suburbans. I reckon it's up to you to decide if you want them, or need them.
Member Nr. 2770
Old 02-09-2008, 04:15 AM   #6
71 super
71 super's Avatar
THE SUBURBAN THING IS NOT TRUE. tHEY CAME STANDARD ON THE HIGHER END TRUCKS SO ALL DO NOT HAVE THEM SUB, BLAZER,P/U. EXPECT TO SEE THE ON CHEYENNE AND SUPER MODELS. AS FAR AS I KNOW THEY WERE PART OF THE CUSTOM COMFORT AND CONVIENCE ITEM PACKAGE. THEY STAPLE TO THE METAL BRACKETS AS THE ORIGINALS DID. MORE CAME WITHOUT THEM THAN CAME WITH THEM.
Old 02-09-2008, 04:37 AM   #7
68gmsee
Active Member
68gmsee's Avatar
I guess both of mine were low end farm trucks cause they ain't got them.
Thanks for the info.
Old 02-09-2008, 07:49 AM   #8
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
What do they do?
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 02-09-2008, 08:33 AM   #9
71 super
71 super's Avatar
They are there to cut the air down that comes from engine compartment/ splash material through the gap in the front fender and inner fender. They also act as a type of vapor barrier of sorts much like later models have between the cowl and the fender. You can add them to any truck but you have to find the brackets. It is like the heat shield on a big block truck, they can help you determine if a seller has a real cheyenne or super or it is a made truck. Most people either don't know about or don't get this odd pieces.
Old 02-09-2008, 10:00 AM   #10
beautimus
beautimus's Avatar
dog gone it, i just realized that mine were on the 2 old fenders that i scrapped!
oh well, i goofed again !!
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 02-09-2008, 10:37 AM   #11
Jered33
Here are some pictures, the bracket is on the cab not the fender. Mine is attached with hex head screws. Truck is a Super Cheyenne k20.
Looks to just keep dirt and noise out?
Jered33 is offline   Reply With Quote
Old 02-09-2008, 12:54 PM   #12
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Ahhh...so that's what this was all about! Hmm, now I know. Thanks.
ETsC10 is offline   Reply With Quote
