Old 02-08-2008, 03:55 PM   #1
BOSS
Just here to help
BOSS's Avatar
Are 6 lugs longer then the 5 lugs?
A friend of mine was wanting to change axles from his sons truck and wanted to use the 5 lug axles out of a parts truck i have here and he said that the 6 lug was about 3/8 of an inch longer then the 5 lug.Does this sound about right or could one of them had a rear end swap in the past? thanx for the help.
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 02-08-2008, 05:35 PM   #2
68350
68350's Avatar
Re: Are 6 lugs longer then the 5 lugs?
I wanna say that til 70 they used a wider or narrower rearend then switched in 71, but I'm not sure. Why doesn't he change swap the whole rearend? thanks and hope it helps
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 02-08-2008, 08:35 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Boss... that's about right, 3/8 inch per side.
The wide axle was started sometime early/mid 70, but still has the 6 lug.
Old 02-09-2008, 01:30 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Maybe I'm misunderstanding Boss's post but wouldn't the mid 70's 6 lug axles be the same length as the 5 lug axles, and the early six lug axles be shorter than the mid 70's six lug and all of the 5 lug axles?
LockDoc
Leon
Old 02-09-2008, 01:52 AM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
LockDoc
Yes, the early 70' six lugs were shorter than the later 70's six lugs. Thats why the late 70's will direct swap out inner axles and all the older ones make the brake drum stick out on the brake shoes.
They say you can use 73' up drums that are wider to remedy this.
sneakysnake is offline   Reply With Quote
Old 02-09-2008, 01:56 AM   #6
sneakysnake
I just reread the post (Boss) are you refering to the stud length being longer? or axle lengths?
Old 02-09-2008, 03:09 AM   #7
BOSS
Just here to help
BOSS's Avatar
axles are longer.
Support our site
Norwood Survivor
Old 02-09-2008, 04:52 AM   #8
sneakysnake
[QUOTE=BOSS;2567915] He said that the 6 lug was about 3/8 of an inch longer then the 5 lug.QUOTE]
I think it sould be just the opposite, 6 lugs should be the shorter one
http://www.kabele.com/axleshaftsgm.htm
Old 02-09-2008, 05:04 AM   #9
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
6 lugs are shorter. There was a thread in here a few weeks ago on ho he used the 70 6 lug because it was more narrow and he didnt have to adjust to much on the back space on his new wheels.
Angelse68cal is offline   Reply With Quote
Old 02-09-2008, 05:37 AM   #10
LockDoc
LockDoc's Avatar
[quote=sneakysnake;2568487]
That's what I was getting at....
LockDoc
Leon
