Old 02-08-2008, 11:34 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Question h-4 headlights ?????
ok all,
i have been doing some thinking about "switching" over to the new style of headlights & the question(s) is why do the "kits" have a wiring harness or why do you need a wiring harness for them?? i have elec. fans as well as relays for my ac unit & i really don't want to add more relays to the system. can you get the new headlights without having to upgrade the wiring on our trucks??
thanks for the replys.....
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 02-09-2008, 01:29 AM   #2
Musclerodz
Re: h-4 headlights ?????
Originally Posted by rodstored-72 View Post
ok all,
rodstored-72
The original wiring was not designed to take the extra ampereage capacity required by the newer lights. The extra draw on an inadequate size wire or corroded connections creates a potential fire hazard. Also the extra ampereage is being pulled through the original light switch which was not designed for the extra load either. Relays will turn the headlight switch into just that, a switch, very little draw on the switch and wiring system therefore protecting your circuits. We sell the lights with a high quality relay kit included. You can buy the lights without relays, but I don't recommend it.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 02-09-2008, 01:37 AM   #3
jb4short
Damn Yankee
jb4short's Avatar
I agree with Mike; using the supplied voltage from the switch to trip a relay and introduce power from a direct source is much safer
jb4short is offline   Reply With Quote
Old 02-09-2008, 02:02 AM   #4
Andy4639
Old member
Andy4639's Avatar
rodstored-72...
Why don't you want to add more relay's? They are the safest way to add accessaries in the older trucks.
Most relay's come with a hookup for two add on's and the power wire can be jumped from relay to relay which if tey are mounted close to each other it's a simple thing to add. My two cents worth anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-09-2008, 04:28 AM   #5
rodstored-72
chevy truck fan
thanks guys,
i thought that was the reason(s) the wire rating, but i didn't know about the switch. my truck is not a daily driver & i am trying to keep the engine bay as clean & simple as possible. i guess i could make a relay "box" & hide all the relays (fans, ac unit & headlights) inside... i dunno i was just wanting a sound board i guess.
thanks again guys for the time & help....
on a side note do you guys think adding the lights are a good thing? (asthetic & safety) ????
Old 02-09-2008, 06:35 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
in reality, adding relays to the normal sealed beams is a huge improvement.
Old 02-09-2008, 07:46 AM   #7
Andy4639
Old member
Andy4639's Avatar
I added the headlights a few year's ago and just added the relay's a few weeks ago. Made a big differance at night. Both of them. Once the cold air intake is back in place you can't see none of the wiring.
Old 02-09-2008, 10:56 AM   #8
clay68c10
clay68c10's Avatar
Go for it, the relays are the way to do it. With the relays supplying my H4's, they're almost as bright as my '04 VW headlights.
Asthetically, you can hide a lot of stuff on the core support without it being very visible if you wrap your wiring with black tape or loom and mount things low.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-09-2008, 02:20 PM   #9
c-10ss
just get a lmc headlight harnest for the h-4 bulds , no cuttin ,no slpicing
real simple to install
c-10ss is offline   Reply With Quote
Old 02-09-2008, 08:36 PM   #10
Longhorn Man
You are better off making your own than buying the LMC kit,... and then replacing the relays in 6 to 8 months.
Old 02-10-2008, 02:02 AM   #11
Musclerodz
sorry but the LMC relay kit is junk.
Mike Redpath
Old 02-10-2008, 02:18 AM   #12
Musclerodz
double post
Mike Redpath
Old 02-10-2008, 01:27 PM   #13
1969stepside
1969stepside's Avatar
does anyone have the blue bulbs for their headlights
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-11-2008, 01:28 AM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I hate blue bulbs -- I once bought some high $$ Hyper-White blue bulbs (with a money-back guarantee!) and drove home (an hour over the mountain) and promptly removed them. The guy returned my money as promised. I couldn't see squat and later found out why. http://www.danielsternlighting.com/t...e/bad/bad.html
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-11-2008, 01:52 AM   #15
jb4short
Damn Yankee
jb4short's Avatar
I have nice dual-function H4 HID kits with clear glass capsules....but we haven't decided to sell them or not....
I know Mike wants my set...LOL
Old 02-11-2008, 03:21 AM   #16
BustedTruck
BustedTruck's Avatar
[QUOTE=Tri-ProAutomotive;2571186]I have nice dual-function H4 HID kits with clear glass capsules....but we haven't decided to sell them or not....
Where can I purchase a set of these?
BustedTruck is offline   Reply With Quote
Old 02-11-2008, 06:14 AM   #17
1969stepside
yea where can i get a set of those lmc has the bulbs and i was wondering if anyone had bought them cause i have a set on my xtreme and i want a set for my 69
Members i Have met
Earl Slick68
Old 02-11-2008, 06:20 AM   #18
jb4short
Damn Yankee
jb4short's Avatar
[quote=BustedTruck;2571260]
Right now I've only seen them available at chevsofthe40's
We thought we could do them for about half what they sell for
Old 02-12-2008, 12:36 AM   #19
Andy4639
Old member
Andy4639's Avatar
I have a set of blue bulb's in mine now, that I took out of my daughter's Eclipse. I can't tell a differance. Same watt as the clear that came with the tri-bar lights.
Old 02-12-2008, 12:46 AM   #20
jsbgump
Gone Fishing
jsbgump's Avatar
I just bought a set of the h-4 headlights. ow all I need to do is do the relay install and buy the silverstar headlight bulb ans it will be good to go
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-12-2008, 02:00 AM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
From Stern's site, if you are interested:
Osram, the well-established German lampmaker, sells a line of automotive bulbs they call "Silver Star". These are Osram's top-of-the-range headlamp bulbs, equivalent to Narva RangePower+50, GE Night Hawk, Philips VisionPlus, and Tungsram Megalight Premium. They produce the maximum legal amount of light while staying within legal power consumption limits. They have colorless clear glass.
Osram bought the well-established American lampmaker Sylvania in the early 1990s, so Osram is now Sylvania's parent company. Sylvania also sells a line of automotive bulbs they call "Silver Star", but it's not the same product. The Sylvania Silver Stars have blue glass. Light output is of legal levels, but as with all blue-filtered bulbs, you do not get more light from them. The Sylvania SilverStar bulbs have a very short lifetime, because the filament is overdriven to get a legal amount of light despite the blue glass.
- Mike -
RIP El Jay
Old 02-12-2008, 03:57 AM   #22
jsbgump
Gone Fishing
jsbgump's Avatar
Thanks for the info. I had a set of them in a sunfire that I drove for 3 years with them in it with no problems
Build Thread
Old 02-12-2008, 06:13 AM   #23
Jcentsr6
Junior Member
Jcentsr6's Avatar
I installed the H4 headlamps....have not yet installed the harness yet, but dont drive it at night untill summer. I also bought a HID kit for the truck as well..I will be installing those when the harness is installed. I will not drive another vehicle without HID's after having them in my last truck....Makes a huge diff.
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 02-12-2008, 06:21 AM   #24
Musclerodz
Did you get the problems worked out? Pm or email me.
Mike
Mike Redpath
Old 02-12-2008, 09:09 AM   #25
Andy4639
Old member
Andy4639's Avatar
Here are the bulbs I installed in the Tri-Bar light's.
