02-09-2008, 04:58 AM | #1 |
What do these fit???
I bought these hucaps for my 68 C10 6 lug, but they have a extra lip on the back of the hubcap that looks like it fits inside the rim instead of outside. the inside dia is 8 3/4"
02-09-2008, 06:55 AM | #2 |
Re: What do these fit???
I could tell for shure if I saw the other side, but I think they are for 3/4 ton with 17.5 wheels & 1 ton with 19.5 single wheels. If so they are very rare & valuable.
02-09-2008, 03:13 PM | #3 |
Here is a pic from the side and the front. As you can see someone tried to paint them, I was going to strip them and re-paint the original colors.
02-09-2008, 07:02 PM | #4 |
Those fit the wheels with the spring clips riveted on. I think the diameter makes them for a 1/2 ton.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
02-09-2008, 11:39 PM | #5 |
Active Member
If you figure out a good way to repaint like original, post a "how to" here... I've been trying to redo my 68 GMC ones for some time and haven't found a method that I'm satisfied with.. I guess the may reason is that mine say GMC in the front.
02-10-2008, 12:36 AM | #6 |
I've got an extra rim with the spring clips and the hub caps don't fit on it. I was going to paint them the stock silver and have a pinstriper do the details then do a satin clear coat over top.
