How to pull the cab off?
Its that time in my build(well deconstruction) to pull of the cab. How should I go about doing this?
I will be using a forklift but can i just run a couple tow straps through the cab and lift or should i use a timber to lift? I just dont want to dent or warp the doorjams or the roof. Thanks for the help, Wes
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD |
The Crazy Machanic
Re: How to pull the cab off?
well if it was me and i had to do it again (ive removed about 3 cabs now
(id get a jack lift all four corners then make it soo its sitting off of from high enought and just roll frame out from under it. then lower cab onto a rolling cart. but thats me tho (but i didnt have acess to a fork lift.) But id still use my idea remove borth rear and front glass put tow by whatever through cab and put forks through rear window and lift like that (the cab will be stong enough like that to carry its self)
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() Last edited by Srubydo1986; 02-09-2008 at 11:14 AM. |
#3 | |
When I went and got my one-piece rear window I just used a couple of straight blades and slowly worked it out. Should I do that with the front as well? Thanks, Wes
Professional Grade
Front you can pull with your bare hands if it is reasonably warm, but seeing that you are in Olds, and it ain't particularly warm here or there at the moment, you'll probably need a piece of wire to work it out with...
Personally, I took a pair of 4x4s and stuck them through the windows, then ran straps up to the forks on the bobcat, and lifted it from the side. Just make sure you don't run into it with the machine and it should come off pretty easy. Also, make sure you've got EVERYTHING unhooked first, and that you have a spotter to watch and make sure you arn't testing the tensile strength of anything...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#5 | |
Thanks for all the help everyone, Wes P.S Russell its been a nice 0 degrees here today and yesterday but is supposed to drop by saturday. Stay warm.
Robert Olson Transport
![]() Join Date: Oct 2002
personally the best way i ever did it was with four buddies nothing gets broken that way lift it off and lay it on the cart
Truck and auto performance nut
if you have 4 sturdy mount points (I used the front 2 cab mount bolts and 2 of the seat belt bolts)...you can attach some straps that attach to the 4 points on an engine leveler...attached to a hoist positioned through the side of the cab (w/door off), adjust the leveler...and lift it up with the hoist. Just make the straps short enough so the hoist can lift the cab from inside, without hitting the roof of the cab. Thats how I did mine on my '68.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
I always used a case of beer. 4 to 6 buddiesa can move a cab, and the case of beer costs much less than any of this equipment being discussed.
1970 long fleet, 355 4 speed, primer, walnut goodies |
#9 | ||
![]() Quote:
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD Last edited by 1980GMC; 02-10-2008 at 01:42 AM. |
I agree with 68GMCCUSTOM. I changed my cab recently and used the same approach. I used a 1.5 inch hole saw to get to the cab mounts from the inside.
I lifted an 88-98 bare crew cab with the doors on it with straps through the door window openings and didn't warp it any. The added weight of mine being a crew might be comparable to a standard cab with all it's stuff still in it.
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels ![]() Who needs a car when they make crew cab trucks? |
well...it isn't rock solid, no. I had a guy available to help push the hoist while I steadied the cab. We moved it from one chassis across the shop to the other chassis, on a rough floor, with no real trouble. I might have been able to handle it by myself on a smooth floor.
#13 |
Old Time Rodder
Just installed a better cab on my 79 and was best handled by 4 strong backs. Cab was a little front heavy but was handled well by a couple stronger men.
Removed my old cab by jacking up and rolling chassis out. If I had gotten six strong men I could have changed from one to the other at the same time and saved a lot of time. You would need at least remove the doors for weight saving. I stripped both cabs and was able be handled by 4 men. My biggest problem was getting a group together to help. Everyone said they would but weren't available at the same time. When I did change it last Saturday, I had all those that had volunteered plus a couple extra (9 all total). Shame they weren't available when I needed them most. Trouble was they weren't probably as concerned about getting done as I was. Such is life. Good luck getting yours done as easy and efficient as possible.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
#14 |
I finally got it off today.
![]() Just asked a bunch of friends (6 including myself) to come out to the shop at lunch and we got it off with minor trouble. Could've used one more hand maybe to move things but for 6 high school kids it was suprisingly light and easy. Thanks for all the help and ideas, Wes
