Old 02-09-2008, 10:35 AM   #1
BCOWANWHEELS
generator light is dimly on and no charging battery question...
well i need help again..... i pulled in the driveway and my generator light in the dash came on dimly.... so i unhooked the battery and the engine died so i figured the alternator was bad. i took it off and got a new one and still have the same problem ! then i got a new voltage regulator and installed it, same problem didnt help a thing. anybody got any tips to trouble shoot my problem ? all fuses are good. checked wireing and no apparent problems. i need help !!!!
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 02-09-2008, 10:43 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: generator light is dimly on and no charging battery question...
Been there done the same thing on my GMC. A second voltage regulator fixed mine, though. The guy told me that the alternator damaged my original so when I replaced the alternator I should have also replaced the voltage regulator. Hopefully yours is the same problem.
68gmsee is offline   Reply With Quote
Old 02-09-2008, 10:49 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Just reread your post. You did replace the voltage regulator after the new alternator. It still could be a new defective regulator or even alternator. A long time ago I had to replace a voltage regulator twice. The new ones are electronic circuitry and can be easily damaged by a short.
Old 02-13-2008, 08:57 AM   #4
BCOWANWHEELS
well i cant seem to find the dog gone short or ground in my charging system so today i went and bought a 105 amp, 1 wire alternator and i,am gonna install it tomarrow and be done with it all. man wireing problems are buggers....
bob
Old 02-13-2008, 10:52 AM   #5
463
463's Avatar
a quick check to see if the alternator is charging is to take a screwdriver and put the tip to the rear bearing cap when the truck is running if is pulled in (magnetized) the system is charging. voltage regulator & alternator should be both changed out at the same time. here is a link on this forn that has the alternator change up to the internal regulated alternater. this is what i did last fall (should have did this 20 years ago) nice easy change up and best of all 14.7 volts. link:http://67-72chevytrucks.com/vboard/s...=119379&page=2
463 is offline   Reply With Quote
Old 02-14-2008, 12:20 PM   #6
BCOWANWHEELS
all i did was go to my local alternator rebuilder and get a 105 amp gm 1 wire alternator. it bolted right on. then i unpluged the voltage regulator, cut the large red wire near the plug, spliced a piece of # 10 wire to it where i cut it and ran it to the terminal on the back of the alternator. all done. works perfect. i do think i,am gonna install a volt or amp gauge under my dash though soon. total cost $59.00
bob
