Old 02-09-2008, 10:39 AM   #1
cj66c10
Question GM Column help
Does anyone know where I can find a wiring diagram of the harness coming out of a GM Tilt column? I have no idea what year the column is, it was in the truck when I bought it.
thanks,
CJ
cj66c10 is offline   Reply With Quote
Old 02-09-2008, 10:56 AM   #2
89 crew
Re: GM Column help
With pictures someone can probably identify the column. from there you should be able to find the diagram you need.
89 crew is offline   Reply With Quote
Old 02-09-2008, 11:45 AM   #3
cj66c10
Re: GM Column help
I will try and get some pics. It is a flat rectangular plug with 10 wires in it.
Old 02-09-2008, 12:25 PM   #4
slepysal
slepysal's Avatar
Re: GM Column help
try this http://www.ididitinc.com/instructions.htm
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-09-2008, 02:27 PM   #5
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Re: GM Column help
color function
black horn
light blue left fr signal
blue right fr signal
brown hazzard
purple flasher
yellow left rear signal
green right rear signal
white brake switch
there are 2 sizes of connector: 3 7/8 and 4 1/4
kdrodworks316 is offline   Reply With Quote
Old 02-11-2008, 05:54 AM   #6
cj66c10
Re: GM Column help
Thanks for the info. I was able to get the turn signals working earlier today. Now the only problem is they won't flash when the headlights are on. It had a new wiring harness "installed" by the previous owner.
Old 02-14-2008, 10:25 AM   #7
cj66c10
Re: GM Column help
any ideas why the turn signals stop flashing when the headlights are on or the brake lights come on?
Old 02-14-2008, 12:02 PM   #8
89 crew
Re: GM Column help
I would guess a bad ground. I would start looking for it at the tail lights. Take a long piece of wire. I use an old extension cord with the ends cut off. tie one end to the neg terminal of battery then the other to the rear grounds. then test to see if the problem is still there. Does all the lights work? do they all seem to be bright and even?
Old 02-14-2008, 12:57 PM   #9
cj66c10
Re: GM Column help
they all look pretty bright, right rear may be a little dim. thanks for the info, I'll try checking the grounds
