Old 02-09-2008, 10:43 AM   #1
kxnomore
kxnomore's Avatar
Easiest way to swap out front suspension
Hey guys. The previous owner of my truck put in 8 lug 3/4 ton front suspension on a Cheyenne 10. I have a great donor truck that I want to swap all the correct front suspension parts over: Brakes, A arms, springs, spindles, shocks, etc.
What's the fastest/ easiest way to change these parts back to stock?
kxnomore is offline   Reply With Quote
Old 02-09-2008, 10:47 AM   #2
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: Easiest way to swap out front suspension
doing a compete frt crossmember swap seems to be the less work involved unless you plan on cleaning up all of the components piece by piece then I suggest removing each individual piece from each set up while cleaning,painting and rebuilding the parts in the process.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-09-2008, 10:52 AM   #3
kxnomore
kxnomore's Avatar
So on the complete swap over, how many bolts are involved, and are they easy to get out with the engine in? Does the crossmember come out all in one piece with the A arms and everything?
Old 02-09-2008, 10:58 AM   #4
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Crossmember swaps can be done with engines in but will be more complicated. An engine hoist or a way to support the engine will be needed since the engine stands (where motor mounts attach to frame) are bolted to the crossmember.
Old 02-09-2008, 11:03 AM   #5
kxnomore
kxnomore's Avatar
Ah. Good advice here. So is the crossmember the same in 3/4 ton and 1/2 ton 2 wheel drives? I'm thinking in my case it's better to swap A arms, etc. only, if possible.
