Old 02-09-2008, 10:55 AM   #1
Jered33
Exclamation 72 k20 Super Cheyenne ??
I'm the second owner of a 72 K20 Super Cheyenne, currently repairing rust in floor and rockers. Truck has houndstooth seating, tilt, dark blue color, wood grain details but no air, I would like to have air in the truck would it be better to add vintage air to the truck or find a new cab that came with air? Or Would it be better to leave truck without? Also this truck has the side travel tanks should I leave them or remove them?
Thanks for your 2 cents!!
Jered33 is offline   Reply With Quote
Old 02-09-2008, 11:01 AM   #2
clay68c10
clay68c10's Avatar
Re: 72 k20 Super Cheyenne ??
I never had a/c till I moved down here to the nuclear summer zone from Wyoming. If you don't need it, spend your $ on something else. If you do want it, you can spend as much making an old system work right as you can putting in something new. The one benefit to the stock a/c is that you can use recirc or fresh air, all the aftermarket a/c setups I've seen use recirc only.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-10-2008, 01:50 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Welcome to the board, do you by chance have any pics of your truck?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
