Roll Pan Hidden Hitch ????
Does anyone make a rollpan for a fleetside bed that incorporates the hidden hitch behind the lic plate???
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
Re: Roll Pan Hidden Hitch ????
I have seen somewhere, someone bought the roll pan with the plate box then cut a small square in the middle and welding a plate to a 2 inch square tube and bolting the Lic. plate to that and sliding that into the hidden hitch behind and locking inplace.
I had the same idea. I suppose you could cut out the area and I've seen some where there a spring loaded plate holder that could be welded or bolted on?
Car Knocker
Have you looked at these? http://www.streetbeatcustoms.com/cstrolgm6772.html Like what was said you just have to cut a small 2 1/2" square hole in the box for you licence plate to line up your receiver. Nothing to it. I used to have pics of mine but my old computer crashed and my old digital camera is not compatible with this new Vista program.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. Last edited by jay6891; 02-09-2008 at 09:50 PM. |
Thanks!!! This is what I need!!!!!
