02-09-2008, 04:46 PM | #1 |
bagged 68 need help with the drive shaft
ok the truck is some what done but at low speeds i have a wobble, i think its the drive shaft angle at ride highth its @3 degrees uphill. i was told to have it @ 3 to 5 degrees is that right? thanx for your input.
02-09-2008, 05:35 PM | #2 |
Re: bagged 68 need help with the drive shaft
Its about the relative angle to the output shaft on your transmission. If your rear is 3 degree up you want your tranny 3 degrees down
02-10-2008, 03:36 AM | #3 |
Questionable
Check out this page, it helped me figure out what I need to do, so I bookmarked it and saved it for just such an occasion:
http://www.2quicknovas.com/happypinions.html
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
