any different wiper motor ideas out there
I was trying to clean up engine bay and was looking for different wiper motors or something to make it look better besides paint,
Regular guy
Re: any different wiper motor ideas out there
How about a 2004 and up Cadillac Deville?
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. Last edited by 7T7; 02-10-2008 at 12:57 PM. |
In the Forgotten far North.
![]() Join Date: Jul 2007
Ok so what are we looking at in the pic?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 02-10-2008 at 12:12 PM. |
Regular guy
"different wiper motors "
seven-speeds with 5 delays ![]()
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. Last edited by 7T7; 02-10-2008 at 12:42 PM. |
OK, we're getting closer...
Is the second picture you posted mounted in the first picture? ***EDIT*** - OK, now I see it. But the second question still stands. How close to a bolt in was this or was it a completely custom install?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 02-10-2008 at 02:17 PM. |
Been wanting to do a transplant like this for awhile. Not just for looks though. Any info on part numbers? Is there a kit specific for our trucks? Thanks in advance for any information.
Regular guy
The one on my truck is from Detroit Speed and Engineering.
Unfortunately nothing they sell is cheap. But it is well made and works great! Just from reading the original question from blazer2007 that is exactly why I changed mine. http://www.detroitspeed.com/productp...ersal_prod.htm
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
#8 | |
#9 | |
Regular guy
The universal kit comes with an oversized aluminum plate that you trim to fit your firewall. The motor is bolted to that aluminum plate with countersunk bolts. A few new holes are drilled for the aluminum plate to bolt to the firewall. Inside the stock switch was (gleefully) trashed and I made a small metal plate to hold the new round switch to the metal dash. On the stock plastic instrument bezel the hole is square, so I made an aluminum plate that matches my aluminum interior panels but with a round hole for the new round knob. The wiring is very simple. Hot, ground and a weather pack connection. If you had time and one of these wiper motors It looks fairly easy to make your own. The hardest part would be finding the correct switch.
STILL PLAYS WITH TRUX
That look's like a nice up grade from the stock unit and will probably work much better than the stock unit but i really don't see how it looks any cleaner than what the stock unit did it's still a big bulky electric motor hanging off the firewall!
Now if you can mount it on the inside of the air cowl where the wiper transmission arms are then that would clean up the look of the firewall. |
Regular guy
From the original post, I didn’t get the impression he wanted to hide the wiper motor.
He said “looking for different wiper motors or something to make it look better besides paint.” I thought he was looking for a better looking motor. The caddy unit is a much better looking motor. If he wanted to hide the motor and for the smooth street rod look, he could go this route…..http://itsasnapwireandcable.com/wiper_kits.htm ![]()
Frank,
I wasn't trying to offend you or blazer2007 and i did read what he wrote and i was just giving my opinion and making a sugestion that's all. As i stated before it looks like a very nice up grade but i still fail to see how it looks any better than the stock unit did with or without paint as long as it's in view. Last edited by 87 STEPPER; 02-14-2008 at 01:13 AM. |
#13 |
Regular guy
Sorry if my post sounded defensive Bruce.
That wasn’t my intention. You know, I can’t really think of any truly good looking wiper motors. I think they will always look like something just stuck to the firewall. And because of their size are hard to cover up.
