Old 02-10-2008, 02:18 AM   #1
slammed70gmc
shifter noise
Hey guys! I just bought a 70 gmc and i've already done a 4/6 drop. My problem now is that the shifter rattles and grinds in 3rd when i'm slowing down, it also does it whenever i hit a big bump. Its a 3spd conveted to floor shift.
THANKS!
slammed70gmc is offline   Reply With Quote
Old 02-10-2008, 02:50 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: shifter noise
Most probable cause is loose trans mount/ bolts. What makes me think that's the problem is that it rattles when you hit a bump also.
Other cause maybe bad u joints or out of balance drive shaft.. These is most noticeable when decelarating because you remove tension from the driveshaft.
68gmsee is offline   Reply With Quote
