Old 02-10-2008, 09:13 AM   #1
truckn'
truckn''s Avatar
door hing pillar
anyone know who sells door hing pillars, or A pillars. mine are shot
truckn' is offline   Reply With Quote
Old 02-10-2008, 09:57 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: door hing pillar
I am thinking that you would have to find used,or fabricate your own.
If you hold up your new rocker to the new floor pan, you should see that the rocker makes up alot of the hinge pillar that is missing.
(I hope the rockers that you have are the full size type, that go up the hinge pillar and back of the cab.
the only other piece that you can buy is the foot well, however you could just make yourself a paper pattern and cut it out of 18 guage to save time and money,it is just a flat triangle shaped piece.
good luck, I just got done doing some rust repair, and it is not fun...
Old 02-10-2008, 10:09 AM   #3
LILRED66
LILRED66's Avatar
There are no "A" pillar or "B" pillar patch panels being manufactured and offered in the aftermarket. With the rust problems in these areas on the '60-'66 Chevy trucks, someone should produce them. As suggested, you will have to get them from a donor cab or fabricate your own. If you find a cab with good "A" & "B" pillars, you might as well use it instead of cutting them off a good cab and installing them onto a rusty cab.
Good luck with your project.
LILRED66 is offline   Reply With Quote
Old 02-10-2008, 10:26 AM   #4
ryan913
How close are the pillars for the 67-72 trucks? They offer them in after market.
ryan913 is offline   Reply With Quote
Old 02-10-2008, 10:32 AM   #5
truckn'
truckn''s Avatar
has anyone got their cab apart that they could make a paper pattern. I know it's alot to ask, but mine are so shot I don't believe it would do me much good.
Old 02-10-2008, 10:37 AM   #6
neto
neto's Avatar
Lilred66 what are the A and B pillars in the picture above. My brother has a welding shop and frabricates all kinds of things. Maybe I can get him interested in making some.
neto is offline   Reply With Quote
Old 02-10-2008, 10:48 AM   #7
LILRED66
LILRED66's Avatar
On either end of the rocker panel, the door jamb runs up the front and back of the cab, creating the door jamb. The "A" pillar is commonly referred to as the hinge pillar and the "B" pillar is commonly referred to as the strike pillar. The lower portion of each, where they meet the rocker, is the problem area. The lower portion of the "A" pillar usually experiences the most rust of the two. A crafty sheet metal man could fabricate them with relative ease.
I hope this information is helpful.
Old 02-10-2008, 11:14 AM   #8
jonzcustomshop
1961 crewcab
I have a few shots of mine , maybe that will help.
the main thing, just get the door rocker and fender to line up. there is a fender mounting piont that needs to be there, the rest you can basically make up out of sheet metal
Old 02-10-2008, 11:51 AM   #9
suicide 63
classic parts has posted a new door pillar patch in their online catalog but do not have them instock yet i was there last week.They were due in in mid january.
http://www.classicparts.com/prodinfo.asp?number=44-217
suicide 63 is offline   Reply With Quote
Old 02-10-2008, 09:35 PM   #10
jonzcustomshop
1961 crewcab
you also could PM prerunnerrob, he is the one on here doing the crewcab build, he might have that part left over....
Old 02-10-2008, 10:00 PM   #11
truckn'
truckn''s Avatar
good idea thx for the input guys.
Old 02-11-2008, 02:38 PM   #12
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
https://www.classicparts.com/products.asp?dept=234
heres you new pillars, only $35 a side.
kdrodworks316 is offline   Reply With Quote
Old 02-11-2008, 10:00 PM   #13
truckn'
truckn''s Avatar
I got in touch with prerunnerrob, he thinks he may still have his left over, gonna let me know. but that's awsome cause I only need the partial bottom, the rest is in good shape.
