Split Rim Problems
Was wondering if anyone has any knowledge on how to properly remove the ring off a split rim wheel? Found the notch in the ring and I guess you hook it and start prying until it comes free? Any help would greatly be accepted.
It's on a 56 gmc heavy 3/4ton.
Yellow truck club
Re: Split Rim Problems
Those thing should not be messed around with.
![]() ![]() Brian ... ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Ya I know..I'm just trying to remove the tires off the rims.Already took air out.
![]() Join Date: Oct 2007
had a set on my 79 3/4 ton. even with the air out of them i had a hell of a time getting the ring off. trust me save yourself time and fustration. take them to a heavy truck tire shop. those guys know what to do. espically if you plan on using the wheels. I
take it to the tire shop, a bill from your local hospital will add up to way more than the local tire shop charges!
