Doing some rewire on my 72 gmc and does anyone have a diagram as to what and where the wires to coil,solenoid? Truck still has points but somewhere in its history the resistence wire has been removed ( I Think!) not sure what it even looks like.Any help?
BlahBlahBlah
Re: Wiring Question
This thread may help you. If you read through it there are some really large high res pics in there too.
http://67-72chevytrucks.com/vboard/s...d.php?t=185665 |
Re: Wiring Question
Thanks I'll try that.
Re: Wiring Question
Here is a picture of the stock coil wiring from the firewall out. The wiring was stripped from the harness. The pink portion of the wire is the resistance wire and the yellow parts are for the coil and starter solenoid hookups.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: Wiring Question
Do you know what the resistance should be? (Ohm's)
Spanked once
![]() Join Date: Oct 2006
Re: Wiring Question
Here is an option.....
http://67-72chevytrucks.com/vboard/s...llast+resistor |
