help please about brakes
a frend of my has a 1970 drum front and drum rear he does not want to change over to disk but he want to put a power booster on it what port valve does he need or all them the same i thought disk and drum port valve was diffen. if you can help thanks
Disk and drum brakes use diffrent P-valves.
GYRO GEARLOOSE
If you are going to use your old single outlet master, no valve is meeded. Dual master cylinders can be plumbed for cross or front/rear braking. Either way, no valve for all drums.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
Cantankerous Geezer
If you get the master cylinder for a drum/drum setup you don't need a proportioning valve or cross-plumbing. My 69 has drum/drum power brakes with a dual master cylinder.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Ain't we cute?
Tell him to think about www.praisedyno.com for some shoes. That, with power, should make his braking very nice (on par with factory disc).
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 ![]() |
its all about the +6 inches
Never seen a single resivour master cylinder on these trucks...power/non power, drum or disc....they all had daul resivours as far as i know.
huh?
![]() Join Date: May 2000
I agree with longhornmail. My 66 3/4 ton had a single res; and my 67 C10 panel has a dual...
TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
GYRO GEARLOOSE
You're right about the single resevoirs only to '66. I was thinking about my panel when I wrote that, which I changed to dual with drums, then put 78 x-member in, with prop valve.
