670cfm projection unit on a 250?
Is anyone familiar with this product from holley, I can't seem to find any information that tells me whether or not it can be used on 6cyl. applications.
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: 670cfm projection unit on a 250?
I am running a 670 but I,m not sure about a 6 cyl. I'll check back in a few.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Shelby987,
Just called my local speed shop (where I bought my 670) and he asked motor size of the 6 cyl. He said if it's a 292 or larger it would be fine. He said the 570 would be his 1st choice but the 670 would work. Good Luck
Green club
Projection unit?
I have never heard that lingo before.... 500cfm would do fine, heck Holley has a 390cfm 4bbl too that would be nice on a 250 as well.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
That 670 would be way too much on a six. I would look into a 390 4-bbl or a 350 2-bbl. If the engine is hotter than stock, the 500 2-bbl might work well for you too. I beleive the 570 would still be a bit much, but could made to work easier than the 670.
I'm gonna assume that the application is your 70 K20. The 350 2-bbl or 390 4-bbl will give you the best driveability and throttle response. If you do any pulling or towing, it would also help with low end torque than a larger carb.
just to clear up some confusion, the 670 projection unit from holley is a TBI unit, it is not a carb.
Is the Max CFM of a TBI unit really an issue? I figured I could get away with a larger cfm rating on fuel injection?
