Change Bolt Pattern???
Hey guys, on my 62 truck I have 5x5 bolt pattern. I just picked up a sweet set of rally wheels but they are 5X4.75 bolt pattern. Is there a way I could enlarge the holes on the 5X4.75 wheels so that they would fit my 5X5 pattern? I had a idea that if I just ground the holes out a little they would work fine. Then again I was drinking when I thought of that....what do you guys think?
Re: Change Bolt Pattern???
I briefly considered re-drilling my 6-lug hubs for 5 on 5, but was talked out of doing so by wiser brains, including a machinist.
Anything that could make your hubs/wheels less than 100% tight and stable could cause you bad vibrations, possibly to lose wheel studs or a wheel at some point. These are pretty heavy trucks. |
It is very dangerous to do this to stamped steal wheels. They have a chamfer that the lug nut seats into and if you open up the hole, the nut will not seat properly causing stress, that leads to metal fatigue, that leads to failure. I would advise you not to do it.
From an engineering perspective, I think you'd be nuts to drill out the holes. Besides unintentional weakening, on many wheels (those that use tapered nuts) the holes provide the centering.
You could probably swap the rotors and axles and end up where you need to be, or alternatively, sell the wheels and buy the same style with 5 on 5. I just can't see a good way to modify the parts you have.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
Don't do the wheels! You would end up with a bad accident waiting to happen.
However you could drill the rotors to the 4 3/4 pattern and replace the studs.Some people don't like this either,but I've seen it done before. I tried to find front rotors with that pattern but didn't have any luck. Last edited by olsofti; 02-12-2008 at 01:55 PM. Reason: Didn't like the icon |
damn! Im gonna have to quit thinking about my truck while I drink. Thanks for all the help guys.
#7 | ||
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 02-13-2008 at 02:42 AM. |
