Old 02-11-2008, 11:31 AM   #1
KSCHEVYUP
KSCHEVYUP's Avatar
Longhorn bed mount brackets
Does anyone out their know?
I have a 72 C30 with a utility bed on it. (Plumbers special!)
I want to put the Longhorn bed that I have on it instead.
Are the brackets that are riveted to the frame to attach the bed to different on a longhorn or a 1 ton frame?
In other words, What do I need to Git-r-done?
Ron
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 02-11-2008, 01:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Longhorn bed mount brackets
if yours was a cab-chassis truck originally, then yes, you'll need the factory bed mounts.
Old 02-11-2008, 01:56 PM   #3
Longhorn Man
here's the best photo I have of my one ton longhorn with no bed on it
Old 02-11-2008, 02:00 PM   #4
Longhorn Man
after looking again... here's a couple more shots...
Old 02-11-2008, 10:28 PM   #5
KSCHEVYUP
KSCHEVYUP's Avatar
Longhorn Man-
Thanks for the info and pics
More questions; though
Will I need the mounts off of a 1 ton frame?
And how many brackets am I needing total
4 or 8?
Ron
Old 02-12-2008, 12:27 AM   #6
Longhorn Man
if the windchill wasn't like eleventybillion below zero, I'd go out and double check... but since it is...
I *think* it's just the 4 up front. I thenk the rest of it mounts directly to the frame.
Old 02-12-2008, 12:47 AM   #7
KSCHEVYUP
KSCHEVYUP's Avatar
Longhorn Man-
As I look at your pics some more; the brackets I was cornfused about are the overload spring stops. I was wondering if the 1 ton bed brackets were different than the 1/2 or 3/4 ton frame brackets as I was under the impression that the 1 ton frames ,133" wheelbase, were heavier made and thusly a different size. I have a couple of 1/2 parts trucks if those bed mounts were the same.By the way it is 13 degrees here in sunny Kansas right now. Bet It's a lot colder up your way!
Ron
