L.E.D. Freak
Is there a better more volume fan shroud for the heaters? I want to make a custom center counsle that routes heater/A/C ducts to blow on rear passangers. And need more volume. Any ideas?
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Reumster
I had the same idea. Not yet to that point on the blazer though. My dad has a VintageAir unit on his 71 truck and it has more volume than my wifes 97 Ponitiac GTP. Only problem is it is LOUD!! This is on a non-A/C truck. I bought a center console from a 99 and up extended cab truck for my Blazer. It has A/C vents built into the back for the rear passangers. On a high hump, these consoles fit perfectly. Before I tore the Blazer down for the frame-off, I test fitted the console. It will be awhile before I get to the interior, as the blazer is in a million pieces in the garage. ![]() Later, Chad
Chad ------------------ 69 Short Fleetside 72 2wd Blazer 70 4x4 Blazer 67 Chevy(big window) Just a cab for now 64 Chevelle SS (2dr Ht) |
What about one out of an 85 BMW 528e? It is mounted in the center console right behind and below the heater controls. German quality! Hey wait! I have one! I can get some pictures for you in a week or two ...
Wild
a.k.a. wild4wheels '02 Subaru 2.5ts wagon '67 Chevy C-10 Panel Want to Buy: -Used Car Trailer-Reasonable-in the Midwest -67-72 1 Ton Dually-Reasonable-in the Midwest -BURB QUARTER PANELS! |
Just an idea, but my 93 suburban has an addition fan/squirrel cage in its rear unit. Maybe rigging up an addition fan would suit your needs.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
L.E.D. Freak
All good ideas. But if I rigged another fan in the rear wouldn't I need another heater core? I really would like to keep all the big stuff under the dash and just route ducting.
